Old 07-27-2020, 10:50 AM   #1
vernlee
Default pedal adjustment
My clutch has 1 1/2 '' of free play before I feel significant pressure , no grinding or chatter , the problem is when releasing the clutch it does not re-engage until it reaches that 1 1/12 spot of free play , and then it wants to slip ever so slightly , I was told it is a new clutch and P.plate , Should I adjust to have more free play ? or less free play ? , or is it probably in the P.P spring adjustment , no problem shifting car or going into gear , it is just the pedal has to be almost completely released before engagement .
Vern
vernlee is offline   Reply With Quote
Old 07-27-2020, 11:38 AM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: pedal adjustment
Hmm, remove the inspection cover and take a look.
See how far the pedal has to be pushed before the bearing contacts a finger. I know you said 1.5". Look to see if all the fingers are contacted at the same time.
Work the pedal a few times to see if there is anything wrong/strange.
If all seems Ok I'd try increasing the freeplay just to see what changes.
Old 07-27-2020, 02:00 PM   #3
vernlee
Patrick L ,
thanks I'll give it a try
Old 07-27-2020, 04:55 PM   #4
Mulletwagon
Mulletwagon's Avatar
If no chatter, pretty nomal clutch operation.
Mulletwagon is offline   Reply With Quote
Old 07-27-2020, 04:58 PM   #5
vernlee
I don't think it should be normal for the clutch to slip should it ?
Old 07-27-2020, 05:05 PM   #6
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
No. Do what Patrick said. Report back
Old 07-27-2020, 07:02 PM   #7
Patrick L.
Patrick L.'s Avatar
Well, clutches have to slip a bit depending on what anyone thinks is a slip. But, slippage rarely occurs in lower gears. The clutch really has to be bad to do that. The usual way to find a slipper is to accelerate hard in high gear.
Let us know what happens and we can go from there. We'll try to get it figured out.
Old 07-30-2020, 07:46 PM   #8
vernlee
I got side tracked with honey do projects , I did get the floor out of it and the inspection cover off , just a quick glance at it , everything looks fine , I'll dig deeper into it this weekend .
Vern
Old 08-03-2020, 07:47 AM   #9
vernlee
Got it , one finger was out of adjustment on the P.P. , adjusted my pedal free play to two inches , seems to have fixed the problem , thanks for everyone's help
Vern
