Old 07-27-2020, 07:34 PM   #21
freak
freak's Avatar
Default Re: starter not engaging
Yep
freak is offline   Reply With Quote
Old 07-27-2020, 07:46 PM   #22
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
This is similar to the brake return spring. I can’t see why you would need it, it probably can’t hurt. I have 35 ish starters and have never seen this spring.
Old 07-27-2020, 10:32 PM   #23
freak
freak's Avatar
The bendix with the return spring looks made different to me. You cannot see the pinion gear spiral on this model. On a bendix without the spring you can see the spiral.
Old 07-28-2020, 02:11 PM   #24
Benson
Benson's Avatar
1. That is the REPRO design. If spring is missing from the repro design the bendix gear will "cam forward" and will sometimes strike the flywheel ring gear while engine is running.
Makes a very intermittent low volume 'CHING CHING' noise especially when pointed down hill.
2. The original Bendix model does not have that spring and spiral is quite visible.
Benson is offline   Reply With Quote
Old 07-28-2020, 07:59 PM   #25
freak
freak's Avatar
So if you have one without the spring is it an original part or were they reproduced as well?
Old 07-29-2020, 01:52 PM   #26
Benson
Benson's Avatar
As far as I know the original Bendix design was not reproduced.
Unless Rick, JC Whitney or the Argentina boys sold some repros.
I will ask around.
It seems that several companies made Drives but do not know their names or whether they were of Bendix designs or not.
Old 07-30-2020, 06:41 PM   #27
freak
freak's Avatar
Got the replacement in from Snyders. Here is a comparison between the two. The new one is one the left. The original is stamped "Eclipse Bendix Made in Elmira NY USA" and also has a ton of patent numbers.
Old 07-31-2020, 12:51 AM   #28
Big hammer
Rebuild the one on the right. Do not use grease or oil on the spiral. Good for many years.
get a bigger hammer tap done
Old 07-31-2020, 08:41 AM   #29
freak
freak's Avatar
Yeah it needs a new spring and bolts. Wish I would have included them in my last order to save shipping costs. I'll get them next time I have a bigger order.
Thread Tools
Display Modes
