07-11-2020, 11:51 AM | #1 |
Tie Rods
I am able to rotate my tie rod about 20 degrees. Is that acceptable? If not, is there an adjustment that I can make or do I need to replace my tie rod ends?
Joe/Ct "The older I get, the better I was" |
07-11-2020, 12:21 PM | #2 |
Re: Tie Rods
IMO, 20° is nothing but if it bothers you, loosen one of the Tie-Rod End bolts and rotate the end on the tie-rod by about 10° in the opposite direction, and this should eliminate some of the rotation.
07-11-2020, 01:10 PM | #3 |
Re: Tie Rods
Clarification: The tie rod is rotating when both ends are bolted down. It is rotating on the piece that the tie rod end is attached to...
07-11-2020, 03:08 PM | #4 |
Re: Tie Rods
Joe, I'm not sure I still understand you. So that I am clear, I am going to break this down very elementary on a PDF. Please don't be offended as I am not trying to belittle you, but I want to make sure I understand so that I don't give you bad information.
The A-3281 Spindle Connecting Rod is what I think you are calling a Tie-Rod. This connects both Steering Arms which are bolted to the front Spindles. The A-3285 & A3286 are the Spindle Connecting Rod Ends, and threads onto the Connecting Rod. On each of the Connecting Rod Ends, there is a clamping bolt & nut that go thru the area that I have drawn an arrow in Blue. Are you saying that when this bolt is properly tightened, the Connecting rod still spins inside each Connecting Rod End? . . |
07-11-2020, 07:32 PM | #5 | |
Re: Tie Rods
Brent, thanks for your patience. I am able to tighten the connecting rod ends to both ends of the connecting rod. What I am saying is that, with the ends tightened and the system installed, I am able to rotate that rod by 20 +/- degrees when it is connected to the ball in the steering arms.
07-12-2020, 04:18 AM | #6 |
Re: Tie Rods
John in warm morning Suffolk County England . |
07-13-2020, 08:25 AM | #7 | |
Re: Tie Rods
07-26-2020, 09:13 PM | #8 | |
Re: Tie Rods
sorry for the delay in responding....computer issues. Regarding you question: I am not sure what is in the tie rod end. I have not worked on the front end since purchasing the roadster 15 years ago. I plan, within the month, to "open her up" to see what I have there. I am expecting that I will need to rebuild the ends. Thanks for you patience.
