Old 07-12-2020, 12:21 AM   #21
vilanar
Default Re: Copper coat gasket spray.
I'm with JackShaft. Rattle can silver witch can handle heat ,both sides of composite gasket.
It absorbs it and if in need gasket is easier to remove. Worked great OT twin turbo V8.
Fel Pro´s don't need anything .
vilanar is offline   Reply With Quote
Old 07-12-2020, 08:06 AM   #22
john in illinois
john in illinois's Avatar
Best calls for copper coat on their composite and copper clad head gaskets.
So I follow their recommendation. I use grease on other gaskets such as intake.
John
Welcome each day
john in illinois is offline   Reply With Quote
Old 07-12-2020, 09:53 AM   #23
russcc
Good info. I believe that Best gaskets recommends coating them with Copper Coat, thought I was that on their websiite.
russcc is offline   Reply With Quote
Old 07-12-2020, 10:06 AM   #24
rotorwrench
rotorwrench's Avatar
Most of the old timers I knew used silver spray paint of any brand back in the day. Some paid a few cents extra and used the Copper Coat. Both worked OK.
The silver rattle can enamel has aluminum powder in it and the copper types have copper powder in it. Both are soft metals that will function as a sealer. In aviation, we still used both copper and aluminum washers to seal some banjo bolts. Spark plugs are still sealed with a copper washer to this day.
Old 07-12-2020, 12:15 PM   #25
Fordestes
I have used Aluminum paint most of the time and had zero problems ,I installed a set of offy heads in 1979, I removed them from an 8 B.A after 20 years they were sealed with aluminum paint and there is no sign of corrosion, I also treat my coolant with D.C.A. and also test the voltage in the cooling system every six months.
Fordestes is online now   Reply With Quote
Old 07-12-2020, 08:32 PM   #26
Pete
Pete's Avatar
I once talked to an old modified stock car racer from SC in the 50's that used home rendered lard on his head gaskets.
Smokey Yunick told me to use aluminum paint either spray or brush.
I have never blown a flathead Ford head gasket and we run 14 to 1 compression on circle track engines.
Old 07-12-2020, 10:10 PM   #27
Karl
Karl's Avatar
I have used copper coat on my Model A and T head gaskets.
Yet to do my V8 yet . Tend to use grease on others but more to hold them in place than anything.
Such a fine sight to see-Its a Girl, My Lord, in a Flatbed Ford slowin' down to take a look at me.
Karl is offline   Reply With Quote
Old 07-12-2020, 10:46 PM   #28
Jack Shaft
M151 Nam era jeeps had a steel head gasket, had to spray paint them to seal..Aluminum heads are sexy but are prone to electrolysis,need to run a waste metal bar in the cooling system.Thermal expansion rates are different than Ford grey iron too.
Jack Shaft is offline   Reply With Quote
Thread Tools
Display Modes
