04-03-2020, 06:01 PM | #1 |
Coil bracket? ‘42 and up
Can somebody tell me how this coil bracket works? What does it volt to? Does anybody have a picture of it installed?
Respecting and Resurrecting Ford Model A's. |
04-03-2020, 06:12 PM | #2 |
Re: Coil bracket? ‘42 and up
Looks familiar. But maybe more like a horn bracket? Is this a quiz? 8^) Jack E/NJ
04-03-2020, 06:15 PM | #3 |
It bolts to the left front of the intake manifold and holds an original type coil
04-03-2020, 06:15 PM | #4 |
04-03-2020, 06:37 PM | #5 |
How about some REAL pictures? DD
….and the coil that mounts to the bracket! …….. |
04-03-2020, 07:16 PM | #6 |
04-03-2020, 07:18 PM | #7 |
Ok well that sums up buying one, did not know they were for the original style coil. What are you guys doing when running a modern coil on a 59A engine? My coil wire is pretty short so the modern coil would have to be in around the same spot.
04-03-2020, 07:31 PM | #8 |
I'd fashion some sort of round (coil-sized) clamp that bolts to those two holes....easy peazy! DD
04-03-2020, 08:18 PM | #9 | |
SKIP rebuild, that's how he would mark 6 volts on the side. G.M.
www.fordcollector.com |
04-04-2020, 09:52 AM | #10 |
Make the coil wire longer??
Paul in CT |
04-04-2020, 10:59 AM | #11 |
04-04-2020, 11:26 AM | #12 |
Didn't Mcmimm in Tennessee post he had some original 39 type
coil brackets. I think he wanted $18.00 each. You don't want some abortion hanging on the front of your engine. G.M.
04-04-2020, 11:46 AM | #13 |
Well, this might help you. I am not sure how Coopman found my old pictures, but that is my spare green flathead on a cart and here is pictures of my 27 roadster using that same bracket and a newer style coil like Coopman recommended. Go figure.
04-04-2020, 12:47 PM | #14 | |
Ha...You know what they say...once you post it on the internet, it's there FOREVER! So be careful about posting pics of frolicking-around with all your girlfriends! But seriously, the "SEARCH" function is priceless. I merely typed-in "1948 coil bracket" and your pics were some of several that popped-up. Much appreciated, too! And OH YEAH, great minds obviously think alike!! DD |
04-04-2020, 12:52 PM | #15 | |
04-04-2020, 04:57 PM | #16 |
Thanks for the help on this guys. I know have an idea that I think will work. I cannot use the original style bracket with a modern one the way zzlegend has because my early 21 stud has a waterpump right there. No worries, I will fan something up.
04-04-2020, 05:34 PM | #17 |
I made a little bracket to mount a modern coil on our 34 before I found out about Skips coils, If you want I will drag it out and get a pic of it
Lawrie |
04-04-2020, 06:03 PM | #18 |
I really enjoy making brackets. With a little planning, they are usually less than a one day project, and when they come out the way you want, very satisfying. I had a field day when I put the hemi in my dirt modified.
04-04-2020, 07:05 PM | #19 | |
Me TOO! I've always taken pride in my ability to envision, and then fabricate a bracket to perform some necessary function. It's even better when it's appropriate to make a bracket or fitting out of aluminum, as I love doing fine, hand-finish work with a file to "make-pretty". DD |
04-04-2020, 08:18 PM | #20 |
Shouldn't the coil wires be attached with Ford tube nuts and not hex heads?
