Old 02-25-2020, 12:56 AM   #1
oriondal
oriondal's Avatar
Default Identifying a high compression head
Iíve seen high compression heads described as looking original. Is there an easy visual way to tell the various compression ratios and original heads apart on an installed engine?
oriondal is offline   Reply With Quote
Old 02-25-2020, 06:08 AM   #2
chrs1961815
chrs1961815's Avatar
Default Re: Identifying a high compression head
Usually no, unless there is a manufacters mark on top of the head, which older heads had. But new ones look exactly like an original.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 02-25-2020, 07:11 AM   #3
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Yes kinda, but the word easy might be easier for some over others. The original head should have the delta foundry mark cast on the water pump mount, and the Brumfield had the BF logo and other markings. If you have studied the shape of the original heads enough, you can also discern the slight difference of the top of the BF. The Snyder heads have a small circle cast that has what looks like centering punch marks on the top. Now for some of us who have use sneaky tactics to camouflage an aftermarket H/C head to appear as an original head, all bets are off then.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 02-25-2020, 09:58 AM   #4
Joe K
Joe K's Avatar
Probably the best way is to look at the combustion chamber - and compare it to an original Model A chamber. Different makers of HC heads have different chambers and one can get a sense of who made it from the hidden side.
My X-ray vision isn't what it used to be.
I think my X-ray glasses are in the same box with the Sham-Wow wipers.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 02-25-2020, 12:26 PM   #5
Jim Brierley
Not with any accuracy. The combustion chamber must have its volume measured and figured mathematically for any accuracy.
Jim Brierley is offline   Reply With Quote
Old 02-25-2020, 12:37 PM   #6
Y-Blockhead
Y-Blockhead's Avatar
One thing I noticed is my 5.5 head from Snyder's is the H/C head physically smaller than an original.There was a thread that mentioned this a little while back. You do have to look close tho. Notice head gasket.
Y-Blockhead
'30 Briggs Town Sedan
'55 Ford Ranchwagon
_________________________________
And once again that is just my 1Ę worth.
https://www.youtube.com/watch?v=51ufACHJMfU
Old 02-25-2020, 01:20 PM   #7
Tom Endy
Tom Endy's Avatar
All of the Snyder high compression heads I have seen have two round casting marks about the size of a dime. The photo in post #6 shows them, one on each side of a lug nut. The location varies with the different lots.
Tom Endy
Tom Endy is offline   Reply With Quote
Old 02-25-2020, 01:23 PM   #8
Dodge
Do a compression test.
Dodge is offline   Reply With Quote
Old 02-25-2020, 01:43 PM   #9
Purdy Swoft
Purdy Swoft's Avatar
The original police head had a heart shaped combustion chamber and a compression ratio of 5.2 . The Brumfield 5.9 compression head also has a heart shaped combustion chamber . Combustion chambers can vary in shapes and sizes with different heads . Most of the higher compression heads that I have seen use the heart shaped chamber .
Thread Tools
Display Modes
