Old 11-03-2019, 03:39 PM   #21
F.M.
Default Re: Mysterious hole in valve chamber?
Originally Posted by nick c View Post
It would all go to the center and rear main then to oil return pipe on outside engine. Another question might be where would all the oil go on a long down hill run if the jagged hole was too low.
What would happen if the Engine did not have that pipe ??
F.M. is offline   Reply With Quote
Old 02-23-2020, 02:32 PM   #22
100IH
In cold weather with thick oil and no warmup time , the oil would try to fill the entire valve cavity, starving the rods?
100IH is offline   Reply With Quote
Old 02-23-2020, 02:50 PM   #23
Joe K
Joe K's Avatar
The elevation of the "return pipe" was changed in May 1930 (p. 342) - the same time that the height was changed on the front hole in the block.
The corresponding difference between heights (1/4"?) remains the same (compensation for engine slant) but later positioning of the returns (plural) is lower - "To reduce oil consumption" ostensibly in oil thrown up and onto the valve stems.
Somewhere, in one of the magazines, the "oil control dam" is discussed, and the author made a plastic valve chamber cover - so the oil height could be seen and the effectiveness of either drain port ascertained. IIRC the conclusion of the article proved out Ford's rationale about reduced oil consumption. He also had some comments about the Model B with no oil pipe - and the internal passage for oil.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 02-23-2020, 03:21 PM   #24
Bob C
How about no oil return pipe.
Bob
Bob C is online now   Reply With Quote
Old 02-23-2020, 03:29 PM   #25
Brentwood Bob
Russian influence.
Brentwood Bob is offline   Reply With Quote
Old 02-23-2020, 03:48 PM   #26
Bob C
Originally Posted by Brentwood Bob View Post
Russian influence.
Nope, see Vince's site. http://www.fordgarage.com/pages/ABva...rvarieties.htm
Old 02-23-2020, 05:23 PM   #27
Brentwood Bob
Huh.
A rare bird.
Old 02-24-2020, 02:21 AM   #28
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
The oil pump will pump more than enough oil. If it’s too low a hole, how did the engine survive the first few months of service?
Old 02-24-2020, 07:25 AM   #29
Sunnybrook Farm
Sunnybrook Farm's Avatar
Keep in mind that the oil doesn't just calmly flow around in the engine but is a splash system that turns the inside into an oil mist filled area. A hot fog of oily vapor flows through the chambers and a hole like that would allow the mist too flow into those areas. That is why on old engines the outside around the breather pipe is coated with an oily mess.
Sunnybrook Farm is offline   Reply With Quote
Old 02-24-2020, 07:08 PM   #30
Pete2125
Pete2125's Avatar
Check the hight of the hole against the dam where the valve tapet is. There was a dam where that hole is that let oil flow to the timing gear, however it became popular in the 70's to smash the dam out with a hammer to allow more oil flow to the timing gears. While most peolpe that did this didn't have any problems, there was a side effect. You see sith that dam smashed the oil didn't get high enough in the valve chamber to allow the desired flow to the rear valves, as it had to over come all the seperate dams within the valve chamber.
Pete2125 is offline   Reply With Quote
Thread Tools
Display Modes
