08-25-2019, 08:50 AM | #1 |
wheel question
will tractor tire fit a 29 aa split rim for my doodlebug
08-25-2019, 05:04 PM | #2 |
Re: wheel question
maybe you'd want to run this by a tire dealer...he would know what would work safely.
08-25-2019, 07:24 PM | #3 |
Re: wheel question
https://www.amazon.com/ATV-MASTER-DE...%2C199&sr=8-14
Do some homework on this tire,its a 20",8 inches wide at the tread,it says tubeless but you can probably run a tube with a flap..rim width will be your biggest issue.that being said you can foam fill them,so things like 'holding air' wont be a problem Last edited by Railcarmover; 08-25-2019 at 07:30 PM. |
08-26-2019, 09:25 AM | #4 |
Re: wheel question
They make rear tractor tires in various sizes and widths including 20-inch but they can get expensive. Another option may be the military type tread pattern that Coker is reproducing now. Pete's tire barn shows some narrow 20-inchers. |
