Old 06-07-2017, 03:40 PM   #1
barnfind
Default Flathead with AC - how well does it work ?
I saw this flathead on ePay with a Sanden style AC compressor.
Curious how well AC works - or NOT - on a flathead.
barnfind is offline   Reply With Quote
Old 06-07-2017, 05:18 PM   #2
Art Newland
Art Newland's Avatar
Default Re: Flathead with AC - how well does it work ?
Guys down south run them on Model As a lot. I would think it's got to be better with a V8.
Art Newland is offline   Reply With Quote
Old 06-07-2017, 05:39 PM   #3
Ggmac
The little sanden compressor ( or Sanyo ) doesn't pull much hp , it the generator /alt required that creates some problems . To keep it orig under the hood I've run the compressor off the driveshaft . It's not bad but gets warm on long traffic lights .
Open driveshaft obviously .
Ggmac is offline   Reply With Quote
Old 06-07-2017, 06:35 PM   #4
redmodelt
redmodelt's Avatar
I have see photos posted on mtfca forum of a closed car with a small AC unit installed and remember it's only 20 HP.
Old 06-07-2017, 06:49 PM   #5
38 coupe
38 coupe's Avatar
The issue isn't the compressor on the engine, that works fine. The issue is the condenser in front of the radiator. I've only seen one flathead with good working A/C here in Texas. I have seen several A/C equipped 32-53 cars, but most not what I'd call successful. The one successful install had the condenser about a foot in front of the radiator with lots of air flow around the condenser, in a 41 Mercury. Any install that doesn't allow air flow direct to the radiator causes hot running here. YMMV.
The Model A folks are successfully running A/C since they have room under the car to mount the condenser with a big electric fan. Starting with the double drop frame in 1932 there isn't room. Pickups do have lots of room under the bed and could probably go that route. A really big generator or an alternator are required with this type of installation.
Old 06-07-2017, 06:55 PM   #6
Ardun
Ardun's Avatar
I used Vintage Air's period correct A/C kit with a Sanden Compressor on my 8ba in a '53 Ford and it works fine. Did use an electric fan to prevent over heating. Also used a custom solenoid to kick up the throttle when the compressor clutch activates as those sold by others are throttle stops only which requires hitting the throttle when stopped to get rpms up.
Ardun is offline   Reply With Quote
Old 06-07-2017, 08:37 PM   #7
Ol' Ron
Ol' Ron's Avatar
JWL has one in his 40, and it works great.
Old 06-07-2017, 10:36 PM   #8
Scotty's 52 F3
Scotty's 52 F3's Avatar
I made my own system for my 52 using a Sanden compressor. I'm in AZ. and it works without overheating my engine. My engine is tired so I do notice the load a bit.
Scotty's 52 F3 is offline   Reply With Quote
Old 06-08-2017, 04:18 AM   #9
51 MERC-CT
51 MERC-CT's Avatar
"Period correct"? on a flathead? Please explain.
Old 06-08-2017, 06:02 AM   #10
chuck stevens
chuck stevens's Avatar
I have one on a 40, with a sanden compressor, and vintage air unit. Flathead runs it ok but, it is not like a modern factory a/c. I wouldn't do it again.... open cowl vent, roll the windows down go 60, listen to the flathead pipes.
chuck stevens is offline   Reply With Quote
Old 06-08-2017, 08:05 AM   #11
Johnnydidd
Johnnydidd's Avatar
I put a Vintage Air in my 53 Victoria worked good, I had trouble with over heating, tried electric fan worked great in city, on highway it would over heat. Ended up using 6 blade fan solved problem. The big problem was heat coming back from engine through the firewall and floor board, you must insulate both. It was worth the effort.
Johnnydidd is offline   Reply With Quote
Old 06-08-2017, 08:10 AM   #12
corvette8n
corvette8n's Avatar
As my Dad used to say, his car had 220 air, two windows and 20 miles per hour.
Old 06-08-2017, 09:08 AM   #13
Ardun
Ardun's Avatar
An unnder dash aftermarket unit from the 50's, not integrated. Vintage makes a copy of it.
Old 06-08-2017, 09:15 AM   #14
Ardun
Ardun's Avatar
Throttle "kick up" solenoid. Has the power to move the throttle when the compressor clutch engages.
Old 06-08-2017, 09:49 AM   #15
51 MERC-CT
51 MERC-CT's Avatar
Ah, yes a Mark lV type unit. Had one in my '66 Ranchero.
Old 06-08-2017, 11:02 AM   #16
Ardun
Ardun's Avatar
"Mark IV type unit" is correct. Works well...
Old 06-08-2017, 11:13 AM   #17
jaysberman
Had a 34 coupe with a vintage air unit and an electric fan, never over heated and cooled the car well.
jaysberman is offline   Reply With Quote
Thread Tools
Display Modes
