Old 07-17-2016, 07:58 PM   #1
Special Coupe Frank
Special Coupe Frank's Avatar
Default Darkening original engine bolts...
I searched the Forum earlier today, looking for info about recreating the blackish, "Raven" finish on original engine bolts.
Let me say that I am NOT building a "points car", but would like to come close to correct appearance.
I saw some comments about cleaning the bolts ( de-grease, wire-brush ), heating with a torch, then dunking in used motor-oil.
Can someone suggest a temperature to heat the bolts to if I were to heat the bolts in a pan, say in the oven or gas-grille (don't tell my wife!) ?
It would be a lot more expedient ( and controlled ) to heat a batch of bolts in a controlled manner than for me to do one at time in a flame...
Thanks !
Frank
Special Coupe Frank is offline   Reply With Quote
Old 07-17-2016, 09:29 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Darkening original engine bolts...
I use G-96 gun blueing to darken mine. It does a great job, and as soon as I finish with the blueing I use ATF to oil them and keep the rust away.
I never had luck with Birchwood-Casey, but a guy in our club has made some nice specialty Model A tooling and used BC to darken the parts, and they came out perfect. I must have had a bad jar of the liquid.
Old 07-18-2016, 01:28 AM   #3
Mike V. Florida
Mike V. Florida's Avatar
Thanks !
Frank
Just before red hot.
Old 07-18-2016, 07:54 AM   #4
captndan
captndan's Avatar
I don't like the idea of heating bolts. Gun bluing works just fine IMHO.
captndan is offline   Reply With Quote
Old 07-18-2016, 05:16 PM   #5
msmaron
msmaron's Avatar
Send a message via AIM to msmaron
here is the best to use
Mark Maron
Ill., Region MARC & MAFCA
MARC JSC Member MAFFI Trustee
National Facebook Admin.
https://www.facebook.com/groups/MARC.group/
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 07-18-2016, 06:44 PM   #6
jetmek
If your not looking for high points judging just paint them it will hold up better.
engine and component overhauls my specialty!
Website- www.godevilgarage.com
jetmek is offline   Reply With Quote
Old 07-18-2016, 08:56 PM   #7
CT Jack
CT Jack's Avatar
The raven finish you are looking for is technically called black oxide. If you have a shop nearby that does heat treating and various types of metal plating and finishing they usual have the black oxide process. If you have a sizeable amount they might reprocess them for you. I have tried using naval jelly rust inhibitor which will turn bare steel to a matt black finish. I applied some to my antique tractor splined axle about 10 years ago and it still hasn't rusted.
CT Jack is offline   Reply With Quote
