Old 02-17-2016, 06:03 PM   #1
FrankWest
FrankWest's Avatar
Default Marvel Mystery Oil increases engine HP?
I have heard many stories about adding Marvel Mystery Oil to you oil and gas can increase the performance of an engine. Increase HP?
Has anyone experienced this effect?
FrankWest is offline   Reply With Quote
Old 02-17-2016, 06:13 PM   #2
Dick's Hot Rod Place
Dick's Hot Rod Place's Avatar
Default Re: Marvel Mystery Oil increases engine HP?
Is that what's called "cure all in a can"? Mystery Oil is a good product but I don't think it will add any more HP to your engine. I can see it increasing performance by simply freeing everything up from sludge to carbon.
www.dickshotrodcarbs.com
Dick's Hot Rod Place is offline   Reply With Quote
Old 02-17-2016, 06:14 PM   #3
1931 flamingo
1931 flamingo's Avatar
It's main use is to lubricate the valves, etc. I use it every time I put gas in...........glug, glug, glug.
Paul in CT
Old 02-17-2016, 06:15 PM   #4
SeaSlugs
SeaSlugs's Avatar
yea it may free things up and restore some lost oomph.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 02-17-2016, 06:21 PM   #5
29spcoupe
29spcoupe's Avatar
I used MMM in my 41 Packard. It seemed to help get rid of vapor lock. The fuel line ran pretty close to that long exhaust manifold.
29spcoupe is offline   Reply With Quote
Old 02-17-2016, 06:29 PM   #6
mshmodela
mshmodela's Avatar
If one thinks about it there is no true hard science on 85+ year old engines... They were not designed to last this long... Who can really say what does not work? MMO by the number of mostly positive comments here means the odds are likely it can help some Model A's.
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 02-17-2016, 06:34 PM   #7
CarlG
CarlG's Avatar
I bought a quart of MMO several years ago. Does that count?
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 02-18-2016, 08:35 AM   #8
Bob Bidonde
Bob Bidonde's Avatar
Unbelievable that MMM is a power adder without a dyno test.
I have not seen any test evidence that indicates MMM has value as a gasoline or engine oil additive. Can anyone link us to a test data?
Bob Bidonde
Old 02-18-2016, 11:01 AM   #9
Jon W
Jon W's Avatar
The data is kept in a safe along with the 250 MPG carb we all have heard about.
1928 Model A Phaeton
Knoxville, TN 37914
Jon W is offline   Reply With Quote
Old 02-18-2016, 11:13 AM   #10
Gary WA
Gary WA's Avatar
Nothing on the label about HP so your answer is No Increase in Hp. Lubrication yes Good for Valves.
www.whidbeymodelaclub.com
Old 02-18-2016, 11:14 AM   #11
Y-Blockhead
Y-Blockhead's Avatar
Now Bob. IF there was any proof it would no longer be a "Mystery".
Y-Blockhead
'30 Briggs Town Sedan
'55 Ford Ranchwagon
_________________________________
And once again that is just my 1 worth.
https://www.youtube.com/watch?v=51ufACHJMfU
Old 02-18-2016, 11:26 AM   #12
holdover
back in the 60's we used it to quiet noisy hyd valve lifters, to good effect, then looking and feeling it, it seemed similar to ATF which did about the same thing for less money. I'm sure that it has more additives in it that help things. If it helps the rings from getting gummed up it would add some compression and power, but without dyno results there is no proof.
holdover is offline   Reply With Quote
Old 02-18-2016, 11:31 AM   #13
Gary WA
Gary WA's Avatar
Just like ALL forum sites;Google it and you will have all the answers you need and then some and then you will really be confused.I use it and it "Does help Lubrication due only to the dry ethonal gas"!
Old 02-18-2016, 11:39 AM   #14
burner31
burner31's Avatar
For those that run MMO.
What's the mixture ratio that you use?
I run only pure gas, and have a full tank right now.
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 02-18-2016, 11:42 AM   #15
Tiny
Tiny's Avatar
I run about 3-4 oz in each fresh tank. More of a glug glug eyeball measuring method not officially measuring it
Blackwall Panthers
Nor Cal chapter
Tiny is offline   Reply With Quote
Old 02-18-2016, 11:46 AM   #16
Bob-A
Bob-A's Avatar
Thumbs up Re: Marvel Mystery Oil increases engine HP?
I buy MMO by the gallon at Wally World. I don't use any formula when mixing it with the gas, just pour in what looks to be a good amount. Each time I add non-ethanol gas to the "A".
Bob-A
Bob-A is offline   Reply With Quote
Old 02-18-2016, 12:04 PM   #17
CarlG
CarlG's Avatar
Reminds me of the Geritol and Carters pills ads from the '50s
Alaskan A's
Old 02-18-2016, 12:46 PM   #18
Mikeinnj
Mikeinnj's Avatar
Pure Snake Oil !!!
Gullible buyers think it will preserve their engine forever, cure any ailments, etc.
Waste of money for sure.
A well built and tuned engine is not going to evolve from this "mystery in a bottle".
Mikeinnj is offline   Reply With Quote
Old 02-18-2016, 01:34 PM   #19
Russ/40
Russ/40's Avatar
Reduces pre-ignition problems if that state exists. Lowers volatility of fuel. Preserves fuel freshness, especially in alcohol fuels. Helps retard rust from stagnant alcohol laced fuels. Decreases sludge buildup in vehicles that never see adequate burn off temperatures.
Russ/40 is offline   Reply With Quote
Old 02-18-2016, 02:09 PM   #20
Big hammer
For a ill running engine not a sick engine, using 4oz/ 10 gal gas will help smooth things
This would be the only increase in HP, from running sick to running smooth IMHO
Thread Tools
Display Modes
