Old 09-11-2014, 07:41 PM   #1
1930.68B
1930.68B's Avatar
Default Acceptable rear axle wear
What amount wear is acceptable were the axle passes through the differential gear case? I have axles that measure 1.492 to 1.497. Also what amount wear is acceptable were the inner axle seal rides on the axle? I have one that has a groove worn into the axle about .05 to .06 deep.
1930.68B is offline   Reply With Quote
Old 09-12-2014, 09:12 AM   #2
Ron/IA
Default Re: Acceptable rear axle wear
DITTOU2 - I am not an expert, but have seen groves worn in axles, and they have caused problems leaking for me. Five to six thousandths deep is noticeable where the seal will ride.
As to the wear where the axle passes through the differential gear case; I don't understand. In the gear case the axle is held by a bearing. Are you referring to the play between the axle and said bearing?
Ron/IA
1929 Fordor Steelback
Hawk A Model A Ford Club
http://hawkamodelaclub.org/
Ron/IA is offline   Reply With Quote
Old 09-12-2014, 10:06 AM   #3
Jim Brierley
the seal can be moved slightly outboard to give a new area to wear on
Old 09-12-2014, 10:30 AM   #4
redmodelt
redmodelt's Avatar
How would you move the axle seal in the tube outboard? When they are installed it's bottomed out as far as they will go. Because of the cup shape, they can only be installed one way. You might be able to install inboard a tiny bit if you used a spacer and glue to hold them in place. The area where the seal seats is not that deep, maybe just the thickness of the seal and not much more in the axles housings that I have worked with. An alternative might be to just take a lite under cut just where the seal rides to give it a new surface.
Old 09-12-2014, 03:15 PM   #5
Rocketsled
Rocketsled's Avatar
You could install a 'Speedi Sleeve' on the axle to provide a new surface for the oil seal.
Put some threadlocker or retaining compound on the axle first, to prevent any leak
path under the 'sleeve'.
Rocketsled is offline   Reply With Quote
Old 09-12-2014, 05:05 PM   #6
1930.68B
1930.68B's Avatar
Ron/IA
The differential gear case is supported by the bearings that fit on the case and mate into the axle housing races. The gear end of the axle is supported by the spider gears. I don't have an inside mic but the opening in the differential gear case where the axle passes through case appears to be a 1.5 I.D. The machined surface of the axle going through the case is the location where I'm measuring 1.492 to 1.497. I haven't found anything to tell me the original diameter.
I'm not familiar with a "Speedi Sleeve". Do have the name of a supplier or location they can be purchased?
Old 09-12-2014, 08:45 PM   #7
tbirdtbird
let us know how you make out
'31 180A
tbirdtbird is offline   Reply With Quote
Old 09-13-2014, 01:30 PM   #8
redmodelt
redmodelt's Avatar
The spider gears don't support the axles the carrier does. The function of the spider gears is to allow one axle to turn faster or slower going around a corner. In a stright line the carrier and axles turn as a unit. Depending on the wear of all related parts there will be some float related to the spider gears as they are not held in place and float on the spider. While I don't recall seeing the info you are looking for, I would not worry about .003 to .008.
Old 09-14-2014, 12:39 AM   #9
KR500
KR500's Avatar
I priced some stainless speedi- sleeves from SKF who owns the distribution of the sleeves. They were outrageous in price. Some where in the neighborhood of $26.00 each
KR500 is offline   Reply With Quote
Old 09-14-2014, 12:54 AM   #10
Tom Endy
Tom Endy's Avatar
Originally Posted by tbirdtbird View Post
Speedi sleeves: (there are other makes, also). Once you determine which size you need you get them thru your FLAPS
http://www.skf.com/group/products/se...eve/index.html
What you call the "differential gear case" is generally termed the "carrier"
The axle is supposed to be able to spin inside the carrier else the two would bind and scrape when going around a corner
The absolute best resource for anything to do with a Model A rear end is Tom Endy who posts here often and has been generous enough to have a link to his step-by-step rebuild procedure, which I might add should be followed to the letter, unless you like removing and replacing the rear end
http://www.ocmafc.org/techarticles/T...0Re-Edited.pdf
The differential rebuild article referenced here was written in 2008 and has since been revised in 2014 with more and larger photos and additional instructive information. The 2014 revision runs out to about 65 pages.
The revision can be found on the web site of the Santa Anita A's of Arcadia, CA. Go to santaanitaas.org. On the home page put your cursor over "Technical Reference", my name will appear below, click on it. A menu of 82 articles will open. Scroll down to the one titled differential revision 2014 and click. It is a pdf file, you are welcome to download it and print it out.
Tom Endy
Old 09-14-2014, 07:48 AM   #11
Rocketsled
Rocketsled's Avatar
SPEEDI SLEEVES provide the ideal surface for a seal lip to ride on. Ask your industrial distributor for a better price, or try TCM, which sells a Chinese version.
SKF Sealing Solutions was formerly C/R Seals.
Old 09-14-2014, 09:16 AM   #12
tbirdtbird
still way cheaper than a new axle.....
'31 180A
Old 09-14-2014, 09:35 AM   #13
Kevin in NJ
Things to think about.
The diff carrier wear areas are the faces where the axle bevel gear back face touches, the spyder gear to diff carrier face, and the gear faces.
Wear in these areas contributes to axle end play.
The spyder gears had broached gear faces. They would have lines going along the face if they are not really worn. If they are pretty shiney then they are worn. Also look at the back side and where they go into the carrier. If you have more then one carrier laying about you can see just how worn these areas can get. You also need to look at the carrier faces where the axle back side will be pressing. These can be worn or pitted.
Quite frankly some wear in these areas is not going to ruin your day. But I am sure there is too much wear in a lot of these parts in some rebuilds and the documentation does not seem to address what to look for as to what constitutes too worn. I do not know how to quantify too worn, but I had enough parts in various condition to see that some parts probably should not be used. When you put a NOS side carrier mated to a worn opposite side carrier you can physically see how far worn in the spyder gear mating area is and why some may be worn too much. I just have no idea how to quantify it to share properly.
While I do not know how much this extra wear can affect axle function, experience has shown poor performance of the A is frequently contributed to the collective marginal wear of all the parts.
Just a thought. For the outer axle seal area on the axle. Before you measure first you have to bring the area to a smooth round surface. Shoe shine with emory. Then measure. You also have to consider the type of seal being used. A leather seal is likely to perform better with a marginal sealing surface then a modern seal.
Least we forget. Check the wheel bearing surface for wear on the bottom and in the hub.
Cabriolet and Technical Hints
Old 09-14-2014, 08:06 PM   #14
tbirdtbird
Tom Endy, as always thanks for the superlative update!
dave
'31 180A
