Old 08-02-2020, 09:17 AM   #1
1crosscut
1crosscut's Avatar
Default Help with a Mallory 11A
I have a couple of Model A binder engines that I am starting to work on and need a bit of help with the Mallory distributor that is on one of them.
I have the spring clip removed that holds the upper plate in place but the plate is not wanting to budge. I'm thinking that it is just being held in place simply by crud and how long it has been since it was last removed. I have been soaking the outer edge with PB Blaster and lightly tapping with an aluminum hammer to introduce some vibration to get it freed up. Just wanted to check to see if there is anything else I am missing that would be preventing it from coming apart.
Also where would I look to find points and such for it?
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 08-02-2020, 09:19 AM   #2
1crosscut
1crosscut's Avatar
Default Re: Help with a Mallory 11A
Pictures would probably help.
Old 08-02-2020, 09:36 AM   #3
Jack Shaft
the 'white crust of death' is what I call it when i see it in a carburetor bowl..try a little CLR,calcium/ lime/ rust remover. Dual points are sexy.
Old 08-02-2020, 04:47 PM   #4
1crosscut
1crosscut's Avatar
Thanks Jack.
Anyone have experience opening one of these up or photos of the innards?
Old 08-02-2020, 09:50 PM   #5
updraught
updraught's Avatar
Not sure what a "Model S" is. Some photos of one for sale previously.
https://www.jalopyjournal.com/forum/...utors.1096539/
updraught is offline   Reply With Quote
Old 08-03-2020, 08:51 AM   #6
1crosscut
1crosscut's Avatar
Thanks, by looking at the pictures it should lift out of there. Just have to get it unstuck.
Old 08-03-2020, 12:23 PM   #7
1crosscut
1crosscut's Avatar
Gently warmed the body of the distributor with a propane torch and it lifted out quite nicely.
Anyone know of a good source for the points and condenser?
Old 08-31-2020, 01:09 PM   #8
callcoy
Mallory was sold several years ago, parts are not available from the new owner MSD which I think I heard is now part of Mr. Gasket or the other way around. You will have to watch the parts for sale section here, EBAY or Jalopy Journal. If you are real good with your hands you could most likely adapt points for a more modern source. Do not drop your rotor or cap or you will be Sxxt out of luck! If you run out of options and wish to sell someday, I maybe interested. Hope you find what you need!
Steve - Santa Rosa
callcoy is offline   Reply With Quote
Old 08-31-2020, 01:51 PM   #9
Werner
Werner's Avatar
Dave,
would you please tell me the term
Thanks in advance!
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 08-31-2020, 02:34 PM   #10
40 Deluxe
Originally Posted by Werner View Post
Dave,
would you please tell me the term Thanks in advance!
A "binder" is a farm machine for harvesting small grain. What most guys refer to as a binder is, I think, incorrect. Most A engines used in farming were on combines, mostly ones made by Allis-Chalmers under the Gleaner brand.
A binder cut the standing grain stalks, gathered them into bundles and tied twine around to hold the bundles together, then dropped them on the ground. The bundles were them hauled to the farm yard where they were put through a stationary machine (threshing machine) to separate the grain from the stalks. When machines were developed that did the separating right in the field (combines) binders were no longer needed nor used.
Old 08-31-2020, 02:34 PM   #11
Bob C
Binder= Combine.
Old 08-31-2020, 06:47 PM   #12
40 Deluxe
Originally Posted by Bob C View Post
Binder= Combine.
Not really. A binder cut the wheat or oats and tied it into bundles which were loaded on a wagon and hauled to a stationary threshing machine. A combine went to the field and picked up the grain and threshed it as it went through the field. So the combine eliminated the need for the binder(thus the name "combine," as it combined the cutting and threshing operations into one).
Old 08-31-2020, 07:19 PM   #13
Bob C
OK I stand corrected.
How about this?
Old 08-31-2020, 08:56 PM   #14
Ray in La Mesa
Bubbasignition.com has been rebuilding Mallorys for years, contact them.
Ray in La Mesa is offline   Reply With Quote
Old 08-31-2020, 10:22 PM   #15
1crosscut
1crosscut's Avatar
Werner I think that they may have answered you question.
I tried Bubba's Ignition. I think he has had some health troubles and may not be working on them anymore. Tried calling several times and line is not in service.
I did find a gent in Canada that had some points and I bought several of them from him. I expect to see them in the mail in the next few days. Fingers crossed that they are correct for what I have.
