Old 07-29-2020, 11:16 AM   #1
Licensed to kill
Licensed to kill's Avatar
Default assembling the Model A engine.
Wound this video and found it rather interesting. Especially the part about bearing clearances. I don't know if this method is specific to NEW babbit but found his comment about "everything you thought you knew about building engines...forget it". Thoughts on the interference fit of the crank journals??. https://www.youtube.com/watch?v=anDIASMNmCQ
Licensed to kill is offline   Reply With Quote
Old 07-29-2020, 12:10 PM   #2
alexiskai
alexiskai's Avatar
Default Re: assembling the Model A engine.
This video series was the subject of a marathon thread last fall when it aired.
https://www.fordbarn.com/forum/showt...9129&showall=1
Old 07-29-2020, 01:56 PM   #3
Patrick L.
Patrick L.'s Avatar
If you notice the man from Hagerty says he is not familiar with babbitt. I believe him.
Old 07-29-2020, 06:47 PM   #4
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Buy the book model A engine by McGee and McGee
The venders sell it.
Old 07-30-2020, 07:25 AM   #5
Licensed to kill
Thank you. I hadn't seen that thread. Some "interesting" comments.
Old 07-31-2020, 12:08 PM   #6
Jim Brierley
I would never, ever, set up an engine that tight! I've had a local babbitter do a couple of engines, and/or just rods for me. I have added a .001" shim to each an every bearing during assembly, and have always had good luck with babbitted emgines. The crank should easily turn in the block. I have set-up rods on the crank before assembly, to be sure they turn freely. I also fit my pistons a little looser than many recommend. On stock or nearly stock engines I bore to .003", then hone another .0005". On my personal engines, even more clearance.
Old 07-31-2020, 12:32 PM   #7
Bob Bidonde
Bob Bidonde's Avatar
The last engine I overhauled had the main & rod bearings at 0.0015" to 0.002", pistons to cylinder walls at 0.002" to 0.003" and piston pins floating. With new rings fitted, the crankshaft in the short block turned below 50 lbs-ft of torque.
The starter motors always were able to start the rebuilt and overhauled engines in my cars, and these engines have high-compression heads.
Bob Bidonde
