Old 04-09-2015, 06:22 AM   #61
Flysafe
Default Re: Oil pan 59AB photos
Thank you so much for the photos JSeery, have the same lines and holes, that I have been drawing.
If is possible yet, can you take a close-up of the areas that I marked?
Thank you very much.
All the best,
Jorge
Flysafe is offline   Reply With Quote
Old 04-09-2015, 07:44 AM   #62
JSeery
JSeery's Avatar
See if this is what you are looking for. PM me your email address and I will email back the original higher res photos (around 4Mb)
Old 04-09-2015, 11:03 AM   #63
Flysafe
Thank you JSeery.
Old 04-13-2015, 11:43 AM   #64
Flysafe
In progress
Old 04-14-2015, 02:13 PM   #65
Flysafe
Hello all,
This part gave some work, now do the rest of the holes.
Old 04-14-2015, 06:43 PM   #66
Ronnie
Ronnie's Avatar
Originally Posted by Flysafe View Post
Some pictures of the drawing that i have made.
You are showing 8ba timing components they are different from 59a.
R
Ronnie is offline   Reply With Quote
Old 04-14-2015, 06:53 PM   #67
Flysafe
What are the components that are not correct?
Old 04-14-2015, 10:25 PM   #68
Ronnie
Ronnie's Avatar
The timing gears
R
Old 04-14-2015, 10:31 PM   #69
JSeery
JSeery's Avatar
59a and 8ba cams rotate in opposite directions, so the teeth on the gears would be in the opposite direction. The crank gear and the cam gear are matched sets.
Old 04-14-2015, 10:37 PM   #70
Russ/40
Russ/40's Avatar
Simply not true! 59A and 8BA cams turn the same direction. Only the cut of the gears differ.
Old 04-15-2015, 05:44 AM   #71
Flysafe
So it is only the diretion of the teeth gears correct, I need flip over the both gears teeth?
Thank you so much by the notice.
JOrge
Old 04-15-2015, 08:31 AM   #72
Ronnie
Ronnie's Avatar
Nope time to go back to flathead school. "LOL"
R
Old 04-15-2015, 08:36 AM   #73
Ronnie
Ronnie's Avatar
JOrge
Info for you
http://www.vanpeltsales.com/FH_web/F...timinggear.jpg
http://www.vanpeltsales.com/FH_web/F...ngear-alum.jpg
http://www.vanpeltsales.com/FH_web/F...m_1940to48.JPG
http://www.macsautoparts.com/ford_me...passenger.html
http://www.honestcharley.com/hot-rod...-alum-59a.html
R
Old 04-15-2015, 10:53 AM   #74
Flysafe
Thank you so much Ronnie by the notice and the photos too.
As I don't know of any existing engine near me not always it is clear, my support it is photos that I found in my searches or some help from the members of the forum.
Now i believe that is correct, the left that i have, the right it is the new one.
The engine that I have been designed it is the 59AB.
Thank you all for the help
All the best,
Jorge
Old 04-15-2015, 01:50 PM   #75
JSeery
JSeery's Avatar
Sorry about that, not totally awake on that one!!!!! The thrust of the cam is reversed, not the cam rotation. The 59a thrust the cam toward the engine and the 8ba thrust the cam toward to cover because of the cut of the gears. Some days are better than other!
Old 04-15-2015, 01:51 PM   #76
JSeery
JSeery's Avatar
R
Yep, asleep at the wheel on that one!!
Old 11-15-2019, 05:17 PM   #77
Yackobeen
Great work that model is really neat! Would you share a .step file of the 59AB intake manifold?
I would love to 3D print one for my desk!
Jesse
Yackobeen is offline   Reply With Quote
Old 11-15-2019, 07:37 PM   #78
Ronnieroadster
Ronnieroadster's Avatar
Jesse
The original poster was last active on this site in 2015
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder and Driver of the First Ford Flathead bodied roadster to run 200 MPH Record run July 13, 2018 LTA timing association 200.921 from a standing start in one and a half miles burning gasoline.
