Old 05-24-2023, 08:52 PM   #1
Mshaynes21
Default Getting a model t running
Hello
I am a new model T owner. I just bought a 1917 model T couplet. My first Model T. I am told it is one of the rarer body styles but my reason for buying is I really liked the look of it.. Not sure of the originality of everything. I know it has been changed to a distributor. Just wanted to know what I should look at besides engine oil level before trying to start it. It hasn’t been run in awhile and I didn’t want to do any harm by just jumping in and trying to start it. Thanks for any info you can give me.
Mshaynes21 is offline   Reply With Quote
Old 05-24-2023, 09:30 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Getting a model t running
Change the oil and flush the gas tank
Old 05-25-2023, 12:53 AM   #3
redmodelt
redmodelt's Avatar
Get a copy of the owners manual, most dealers carry them, even if it is in the 1915 to 1919 range, it would have about the same information on how to drive a Model T.
Old 05-30-2023, 09:07 PM   #4
mhsprecher
mhsprecher's Avatar
This might help, too: https://www.fordmodelt.net/m/mothballs.htm
1924 Model T Coupe
1928 Model A Roadster
1930 Model A Town Sedan
1939 Deluxe Fordor
1945 pickup
1951 Custom convertible
mhsprecher is offline   Reply With Quote
Old 06-03-2023, 09:52 AM   #5
bgarrett
bgarrett's Avatar
FIRST, take the spark plugs out and put some diesel in the cylinders. You dont want to rotate the engine when its dry inside. leave the plugs out and spin the engine. this will splash the diesel onto the valves and the cylinder walls, and will blow all the diesel out.
SECOND, do all the things the other guys say. clean the points and inside the carburetor as a minimum
bgarrett is offline   Reply With Quote
Old 06-12-2023, 11:01 AM   #6
40 Deluxe
Personally, I'd use something with better lubricating qualities than Diesel fuel! Diesel is good for washing parts in a tub, which shows you that it is a better solvent than lube oil! Use several tablespoons of 0W-20 engine oil in each cylinder, crank over a few revolutions with the plugs out and let it sit for a few days. The oil will trickle down past the rings and lube the lower cylinders and piston skirts.
Old 06-04-2023, 11:54 AM   #7
gz
gz's Avatar
Did you buy the Couplet that was advertised on the MTFCA website? Great car and a great buy. Congrats!
gz is offline   Reply With Quote
Old 06-07-2023, 01:18 AM   #8
Dodge
Love that body style also. Have fun
Dodge is offline   Reply With Quote
Old 06-13-2023, 10:40 PM   #9
Mshaynes21
Sorry. I haven’t checked this in awhile. I bought the one that was located in Canada. Saw it posted in Hemings. Hopefully I can get it going reliably It has been changed over to a distributor and I believe the engine is from 1922. Wood is in great shape. Overall seems to be a solid car Just need to get some issues sorted out with the engine and transmission.
Old 06-22-2023, 08:15 AM   #10
Ed in Maine
You might consider re-packing the front wheel bearings and everything else that Ford recommends. Ed
Old 06-09-2023, 04:15 PM   #11
redmodelt
redmodelt's Avatar
https://www.mtfca.com/discus/messages/29/8538.html
Old 06-12-2023, 03:58 PM   #12
jimTN
It takes spark and fuel to make one run. With the plugs out, try turning the engine over with the switch on if you have a battery in the system. You should be able to hear the coil sing for each piston as you turn the engine over.
