07-03-2012, 11:51 PM | #1 |
Headlamp reflector question.
I found this information in the Ford Service Bulletins (page 362), where it talks about changes to the single bulb reflector. It mentions that the socket sleeve is mounted 1/16 inch above the headlamp axis. I just had two single bulb reflectors re-silvered. I don't know if I have the "old reflectors" or the "new reflectors" (with the socket sleeve 1/16 " above the axis). The reflectors did not come with the car. I'm not sure that I can make precise measurements of the reflectors (I'm going to try and come up with something!). I have a few questions: Does it make any difference which reflectors I have? Will the headlamp still focus correctly? How do you tell which is the "top" of the reflector? My A is a factory '30 Deluxe Coupe, assembled around April/May. Thanks! |
