Old 07-02-2012, 09:18 PM   #1
C26Pinelake
Unhappy Neither head light works !
Tried to used headlights on weekend and neither one came on. All other lights ( brake, dash, tail, turn and cowl ) work. Where do I look first to correct the problem ?
Thanks Wayne
C26Pinelake is offline   Reply With Quote
Old 07-02-2012, 10:20 PM   #2
Gary WA
Gary WA's Avatar
Default Re: Neither head light works !
check bulbs and also a good ground at the sockets. If the original connectors Make sure they are not touching each other the wire ends that is.
www.whidbeymodelaclub.com
Old 07-02-2012, 10:34 PM   #3
Mike V. Florida
Mike V. Florida's Avatar
Thanks Wayne
Headlight bar grounding.
The buckets attach to the headlight bar, the headlight bar attaches to the fender supports, the fender supports to the frame, and the frame to the battery.
