07-01-2012, 05:42 PM | #21 |
Re: Now you know the rest of the story!
Fred, your lower dull colored CM is for a '29 because the rad mounting pads are flush with the top of the CM. The shinny one is for a 30-32 because it has resessed -I think -rad mtg pads and a hole on the left side(viewed from the driver's seat) for the radiator overflow tube.
VCS2, your CM is for a '30-31 because it has recessed rad mounting pads and the hole for the radiator overflow hose on the left end (viewed from driver's seat) |
07-01-2012, 05:49 PM | #22 |
When did Ford change the front engine mounting from the two bolts in the back of the cross member to the saddle with the three springs?
07-01-2012, 06:55 PM | #23 |
This is for the 30-31. The 28-29 crossmembers have the higher, non-recessed radiator mount pads.
07-02-2012, 12:54 AM | #24 |
No one cut the frame horns off back in the day to replace the C M.With the C M removed the frame is quite flimsy and will be no trouble to get the new C M in place.The 28 C M,s had the two ribs pressed in the lower channel & the front mounts were often cut off so the later flexible mount could be used.
07-02-2012, 02:31 AM | #25 |
To get rid of engine vibration. It was a service bulletin.
1928 Model A Business Coupe Rebuild picture gallery here The light at the end of the tunnel has been turned off due to budget cuts. |
07-02-2012, 10:55 AM | #26 | |
Fred Kroon 1929 Std Coupe 1929 Huckster |
07-02-2012, 12:15 PM | #27 |
nix on better cinder blocks. You probably need a set of jack stands anyway. I like the large ones, what's a few more dollars. I can use the large ones to hold the rear end up when I pull the rearend. Bob
07-02-2012, 12:38 PM | #28 | |
I agree NEVER use cinderblocks. Just for anyone reading this thread in the future that does not know this. Cinder blocks are just plain dangerious no matter which way they are placed. I saw a guy testing/running a car held up by cinderblocks once. The engine vibrations cracked a cinderblock on each side of the axle. Down went the axle with the wheels installed and turning. The car went out the garage in reverse and down the driveway. Luckily he was standing in front of the car and transmission was in reverse! If you are spinning the wheels when on stands ... have someone in the driver's seat to stop the car and use wheel chocks on the other two wheels. Last edited by Benson; 07-02-2012 at 10:12 PM. Reason: missing words |
07-02-2012, 03:58 PM | #29 |
After purchasing a pair of 3-ton, and a pair of 4-ton jack stands, I found out that it takes at least 6-ton jack stands to adequately support the frame for a rear end removal.
07-02-2012, 06:10 PM | #30 |
CarlG, I think you are saying its not the weight rating but the footprint. The wider the better. Bill G
07-02-2012, 06:19 PM | #31 |
Well the front cross member is back in!!!! YAAA. It slipped right in. Bolted it down and it looks like a good driver cross member. I took the right shock absorber off and angled it a bit, tapped it a bit and it slid right in.
P.S. Guys I did beef up the supports under the car. I did put the cinder blocks flat with boards on top. Also have a second support sitting on my hydraulic jack. Plus I do not plan on being under the rig until I get it back on the front axle. Thanks again for all your ideas and help.
Fred Kroon 1929 Std Coupe 1929 Huckster Last edited by Fred K-OR; 07-02-2012 at 06:29 PM. |
07-03-2012, 08:41 AM | #32 |
Fred
use the glossy one, it is correct for 29 the other one is early 28 that the back flang used to extend up and bolted to the front of motor someone has cut it off. the big diffrence 29 and 30-31 is the 29 radiator pads is same level as the top flang of the frame, on the 30-31 cross member the radiator pads are about 7/16" below the top flang of the frame |
07-03-2012, 11:58 AM | #33 |
I did go ahead and use the glossy one. It matched the one I took out and seemed to be in better shape.
Thanks guys for all the ideas and help. Think I am on the way to get the "new" engine back in the rig one of these days.
07-03-2012, 12:19 PM | #34 | |
The 3-ton is quite adequate if you are supporting the car from the axle. |
07-03-2012, 05:10 PM | #35 |
CarlG: The whole car only weighs about 2500 lbs. When you were removing rear axle was that with the wheels on??
Paul in CT |
