06-21-2012, 06:25 PM | #1 |
Coupe Seat belts
I am working on installing belts in my '31 Coupe. I've read all I could find and understand the recommended mounting points in back of the seat. My problem is the routing of the belts from there. In order to have them come around the back of the seat cushion, it looks like I have to cut slots in the curved sheet metal piece at the bottom of the seat back. I hope I have described this understandably.
06-21-2012, 06:41 PM | #2 |
Re: Coupe Seat belts
Bruce just finished installing belts in my 31 coupe. Here are a few pictures.
Oklahoma City Model A Restorers Group. |
06-21-2012, 06:47 PM | #3 |
Bruce,
You shouldn't have to do that. I can't get to my coupe this afternoon, but tomorrow I'll try to get some photos of how I did it, if somebody doesn't post a similar answer before then.
06-21-2012, 06:49 PM | #4 |
I just looked at TinCup's pix, and that's pretty much what I did on mine. He just typed faster than I did!
06-21-2012, 07:58 PM | #5 |
I believe in Vol VI of "How to Restore your Model A Ford" published by MAFCA is a set of instructions for seat belts for the coupe.
That article is also downloadable from MAFCA. Check out "A Bear for Safety" in attached MAFCA Link. http://www.mafca.com/seat_belts.html |
06-21-2012, 08:28 PM | #6 |
Bruce, thanks for the Bear reference, that is one of my guides. |
06-21-2012, 09:07 PM | #7 |
yes, slots must be cut and "protected" from chaffing. I used retractable mechinisms and it is really very nice. You mount the retractor to the outter sub frame. It's lots of work but very professional and worth every hour spent.
Jim |
06-21-2012, 09:38 PM | #8 |
here's some pics
06-21-2012, 09:43 PM | #9 |
Nice install Jim
06-22-2012, 12:11 AM | #10 |
Jim, that's a much neater install than I did. Now I'll have to redo mine!
06-22-2012, 03:14 AM | #11 |
Jim, what angle is pic #2 taken from?
Also, how do you get the seat off the tracks for removal? Do you take out the bolts that attach the adjuster assembly and slide it forward? Last edited by Bruce of MN; 06-22-2012 at 07:06 AM. |
06-22-2012, 06:59 AM | #12 |
It's best to have retractable belts so they don't slide off the seat onto your running board aprons
06-22-2012, 09:07 AM | #13 |
As regards how to remove the seat frame from the tracks (if I understood the question correctly) there are 12 machine screws - 6 on each side - that hold the seat frame to the tracks. There are also 4 machine screws located in the center of the seat frame for those installations with seat adjusting mechanisms, although as I recall, I just unthreaded the adjusting mechanism lead screw (as in adjust the seat all the way forward until the lead screw disengages the toggle nut) in order to remove the seat frame from the tracks.
The comment about seat belt retractors (in order to avoid scratching the running board aprons) is very true, which is why I have "Obtain seat belt retractors" and "Repair running board apron scratches' on my to-do list... Model A Seat Belt #01 fb.jpg Model A Seat Belt #07 fb.jpg
Skip Keyser Napa Valley A's Olympic Vintage Auto Club (1980-1982) MARC of San Diego (1977-1978) MAFCA (since 1978) MARC (since 1977) ---------- Model A owners belong in their Model A’s; Model A’s belong on the road. Last edited by Napa Skip; 06-22-2012 at 09:08 AM. Reason: typo |
07-03-2012, 09:20 PM | #14 |
Jim,
I did a similar install in my coupe, but I REALLY like your retractors. Can I ask where you got them? What model they are? Ken
Style beats speed any day, and with a lot fewer tickets. |
07-03-2012, 10:04 PM | #15 |
www.julianos.com
I ordered color Taupe Soft arm belt 24" JU062 anchor plates JU010800 for inside the sub-frame. hand made the "L" brackets that bolt the retractor to the sub-frame I tack welded a rod to the anchor plates so I could slide them into place in the sub-frame. Attached the "L" bracket and then twisted the welded rod until the tack weld broke. |
