Old 07-03-2011, 04:42 PM   #1
29 model-a
29 model-a's Avatar
Question plates C or D which one is correct
I'm looking to buy a pair of plates for my pick-up which plate would be correct for it. One is a D and the other is a C. Also what are they worth, they are original 29. Thanks Pete
29 model-a is offline   Reply With Quote
Old 07-03-2011, 07:22 PM   #2
foxfire42
foxfire42's Avatar
Default Re: plates C or D which one is correct
I looked up the WIS truck plates in the ALPCA archives. The 1929 year was absent. The most I could determine was the letter is the weight class but no where did it say what the weight was for each class. The plates prior to 28 had TRUCK on the plates. The 30/31's didn't as far as I could tell.
Value can be a tough one to determine. There are two values. One for the plate collector and the other for the car collector. Most of the time the plate collector is happy with a single example. The car person is more into pairs since some States require pairs like Oregon and California.
foxfire42 is offline   Reply With Quote
Old 07-04-2011, 06:46 AM   #3
29 model-a
29 model-a's Avatar
btt
Old 07-04-2011, 08:34 AM   #4
IrishHills
IrishHills's Avatar
I bought a pair of beautifully restored Michigan 31 commercial plates for my truck $75, if that helps.
IrishHills is offline   Reply With Quote
Old 07-04-2011, 09:10 AM   #5
Jerry Parr WI
Jerry Parr WI's Avatar
You need to specify the state but since your in WI I will assume. I believe the correct Wisconsin plate for an A is a "B" plate. C and D plates are for heaver cars but C would be better than D. They are by weight of the car but don't have any details. I do remember seeing it published in the past. I did see some B plates at a recent auction but had other interests so don't know what the price was.
Jerry Parr WI is offline   Reply With Quote
