07-21-2020, 08:42 AM | #1 |
vibrates when backing up
I have a car with a 60 hp flathead, in first an second gear it is smooth. when backing up it vibrates an shakes bad. what could be wrong. Thanks for your help.
07-21-2020, 09:45 AM | #2 |
Re: vibrates when backing up
Sounds like clutch chatter.
If so, I would not worry about it.
Jim Cannon Former MAFCA Technical Director "Have a Model A day!" |
07-21-2020, 10:00 AM | #3 |
Mine used to do that also. Clutch chatter. I realized I was slipping the clutch more in reverse than first gear to control my speed while backing up. Now I just let it fully out like I do when going forward and all is OK. No more clutch chatter. It may work for you.
The Master Cylinder Enjoying life at the beach in SoCal... Last edited by The Master Cylinder; 07-21-2020 at 10:29 AM. |
07-21-2020, 10:01 AM | #4 |
Have the same problem in our 1929.
Only when backing. New clutch, pressure plate, pilot and throw out bearings. Going forward it is fine. I just live with it. Slip the clutch with very little gas and it’s not an issue. Enjoy. |
07-21-2020, 11:15 AM | #5 |
I always assume the multiplate clutch is more likely to do this, but obviously it happens with single plate clutches too
07-21-2020, 12:44 PM | #6 |
Paul in CT |
