Old 05-12-2020, 04:06 PM   #41
shew01
shew01's Avatar
Default Re: Distributor stuck
Originally Posted by Patrick L. View Post
That doesn't look as bad as I thought it would. To look at the drive gear the side cover needs to come off.
I’ve never cracked open the head or side of the engine. If I open the side of the engine, how does that shaft come out of the block? I may be “tempting fate” on opening it.
shew01 is offline   Reply With Quote
Old 05-12-2020, 04:44 PM   #42
Patrick L.
Patrick L.'s Avatar
Maybe if that shaft is as good as it looks from your pic and your not interested in looking at the oil drainage [ crud under the side cover] or valve lash then just maybe things are better left alone.
Old 05-12-2020, 06:09 PM   #43
1crosscut
1crosscut's Avatar
Pulling the side cover off and putting it back on again is pretty straight forward.
The thing that complicates it a bit is having the intake and exhaust manifolds in place and having to work around them while you are doing it. Easier with them off but not a deal breaker.
Two bolts to take the oil drain tube off and then the bolts around the edge of the cover come out and the cover comes off. Reverse the process with new gaskets and your all set.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 05-12-2020, 07:28 PM   #44
abachman3
abachman3's Avatar
If you do not remove the lower shaft, at least pour some motor oil down that hole to lubricate the lower shaft. Pour more than just a couple of squirts... it will just end up in the oil pan... so not too much, unless you are changing the oil, then pour the first quart down that hole.
abachman3 is offline   Reply With Quote
Old 05-12-2020, 07:29 PM   #45
shew01
shew01's Avatar
At this point, I’ve had quite the adventure. I think I’m ready to catch my breath and get the car back together. One task keeps leading to another.
Old 05-12-2020, 07:32 PM   #46
shew01
shew01's Avatar
That sounds like a good plan. I’m getting ready to change the oil after I get the car back together. I’ll probably pour some out down that hole before I change the oil.
Old 05-13-2020, 03:09 PM   #47
shew01
shew01's Avatar
I’m putting the car back together. How snug should the distributor hold down screw be tightened on the side of the engine? I’m asking about the screw, not the lock nut that should be tight. I’m thinking the screw itself would be tightened just “shy” of being snug because the distributor shaft rotates against it or near it. Am I correct?
Old 05-13-2020, 03:49 PM   #48
wmws
Just snug not tight. Then tighten the locking nut. It won't be touching the turning shaft only the body containing the shaft.
wmws is offline   Reply With Quote
Old 05-13-2020, 04:13 PM   #49
Patrick L.
Patrick L.'s Avatar
The set screw point sticks to the distributor housing. Just snug it, not tight. Put your 9/16 wrench on the nut and then hold the screw with a screwdriver to keep it from tightening when tightening the jam nut. That screw is there to be just tight enough to keep the distributor from walking up and out and it provides a bit/source of a ground. If you look at the housing you'll see that set screw goes no where near the spinning shaft.
Old 05-13-2020, 04:25 PM   #50
shew01
shew01's Avatar
Thanks. I think it got it set correctly.
Old 05-13-2020, 07:23 PM   #51
Sunnybrook Farm
Sunnybrook Farm's Avatar
Glad you got it fixed, it pays to take your time as I broke one off once and had to drive it out of the head. If you ever want to take the side cover off and see how the shaft and cam gear come out, I have a couple engines sitting over here, it isn't as hard as getting that distributor off!
Sunnybrook Farm is offline   Reply With Quote
Old 05-13-2020, 08:16 PM   #52
GinRicky
Is there any particular reason to go snug not tight on the distributor set screw?
GinRicky is offline   Reply With Quote
Old 05-13-2020, 08:40 PM   #53
J Franklin
J Franklin's Avatar
Even if you don't do any more now you should plan to do it sometime just to check things and get more familiar with your car. I went back to see why you removed the distributor and must have missed the reason. Did it have a problem?
Old 05-13-2020, 08:43 PM   #54
J Franklin
J Franklin's Avatar
It is not necessary, and the lock nut is there to keep it from backing out.
Old 05-13-2020, 09:08 PM   #55
shew01
shew01's Avatar
Default Distributor stuck
It’s related to the thread below. I was trying to deal with one problem at a time in separate threads. One problem kept leading to another.
Cannot Get Rebuilt Ignition Cable to Read 6 Volts on the Points
https://r.tapatalk.com/shareLink/top...ink_source=app
