05-05-2020, 06:57 AM | #1 |
Question: 1940 Ford Radiators.
Hi.
The radiator in my 1941 pickup originally came from my 1940 Ford coupe. It has a pressurised cap. I have seen photos of a vent located top center of the top tank. Mine does not have this. So my question is: Are 1940 radiators normally pressurised? Or are they normally non pressurised and the overflow tube is located in that vent piece at the top? I have a problem with the top tank balooning up. One of the seams has split which I presume is from fatigue due to the movement that happens when it baloons up. If it is supposed to be non pressurised I might rework it to have a vent top dead center. Thanks in advance. Mart. |
05-05-2020, 07:31 AM | #2 |
Re: Question: 1940 Ford Radiators.
49 Fords as most of the 30's and 40's cars/trucks were non pressurized. what pressure cap are you using? 4lbs is about right as it appears your rad has already been converted to a pressure system. still there needs to be a way for the cap to vent out the overpressure and water overfill
05-05-2020, 02:11 PM | #3 |
Even with a new Walker radiator I only use a 7 lb cap on my flathead. If I had an original radiator I'd probably stay at 4lbs. The neck will need to be modified/replaced to accommodate the pressure cap.
05-05-2020, 02:28 PM | #4 |
40 definitely non pressurized. If it was a 40 radiator, it should have a 91A on the back side of the top tank and cap on angled part, not top. IF pressurized, was done at a later date.
05-05-2020, 08:24 PM | #5 |
Flathead radiator upper and lower tanks did not have the necessary built-in reinforcement to withstand any pressurization.
05-05-2020, 08:42 PM | #6 |
05-05-2020, 09:51 PM | #7 |
Actually a 40 would have an 01A embossed in the top tank. Physically it is the same as a 39 or 41.
05-05-2020, 11:15 PM | #8 |
Hi; I found the pressurized rads cooled about 10 degrees better in my stock forty. 4 lb cap. changed to a correct rad for judging and noticed the difference. Newc
05-06-2020, 09:02 AM | #9 |
The 41A-8100-A & B caps were a product that came out at the close of WWII. The post war cars were equipped with these. The 41A-8100-A/B cap was developed to retrofit back to 1938 on those radiators that had a bung that would work with it. Radiators so equipped would have been replacement parts made after the war with few exceptions.
05-06-2020, 09:09 AM | #10 |
05-06-2020, 09:12 AM | #11 | |
Actually no, it would not. A '40 Ford radiator has 91A embossed to the upper tank. The cap is on the slanted end of the top tank. A '41 radiator is (physically) nothing like the '39 or '40. Different size / different shape. The cap is centered on the top.
05-06-2020, 09:15 AM | #12 |
As you surely know, it would not make an engine run cooler. I figured your question to be rhetorical - yes?
It would increase the running temperature of the system before it over flowed but again, it would not aid in running cooler.
05-06-2020, 09:39 AM | #13 |
Higher pressure makes the boiling point higher.
So higher pressure does not make it run cooler, it just raises the temperature it can run at before reaching boiling point. I found the converse effect in a completely different scenario. On test at high altitude in Colorado. Lets bust out the travel kettle and make a nice cup of tea. It was a waste of time. you can't get the the water hot enough due to the lower air pressure. I can see why lots of people are coffee drinkers. mart. |
05-06-2020, 09:46 AM | #14 |
How is the shape different on a 41 radiator from a 40? I have a 41 radiator in my 40 wagon and it bolts in perfect with no interference. I know the filler neck is in the center on the 41 and not on the 40 but how is the overall shape of the radiator different??
05-06-2020, 09:51 AM | #15 |
Can I get a clarification on something. I just looked and most images of 1941 (emphasis on the 1) pickups show what appears to be a conventional looking cap top center of the radiator. Can anyone tell me if that cap is a pressurised cap or just a filler cap with no pressure mechanism??
Mart. |
05-06-2020, 10:56 AM | #16 | |
Think about this for a moment... IF they were the same, why would Ford have changed them for '41? Don't ya think they'd simply keep installing the 39/40 piece?
05-06-2020, 03:48 PM | #17 |
They are very similar between 40 & 41 but not the same. The transition years always end up with odd stuff on them. Most 1942 stuff was carried over to the 1946 model year so there is a lot more similarity there. The radiators for the crankshaft mounted fan all had to work with it and Ford just had to have that hand crank available. A lot of aftermarket ones lost the crank hole for good reason. It was more expensive to double core a radiator than just make a simple single core set up.
Ford started out with the 4 lb pressure cap but quickly went up to 7 lb when the cars kept getting heavier. My old 51 Mercs run warmer than lighter cars even though they have a huge radiator. The 7 lb cap just allows it to run hotter without boiling the coolant out. We drank a lot of coffee when I lived up in Colorado. Thank the Lord (and the radar experts) for micro wave ovens. Last edited by rotorwrench; 05-06-2020 at 03:57 PM. |
05-06-2020, 03:50 PM | #18 |
Yes I do know. I was responding to Newc's post. He implied that the pressurized radiator cooled better. And it may have, but not because it was pressurized
05-06-2020, 07:13 PM | #19 |
05-06-2020, 07:21 PM | #20 |
A BIT narrower.
