Old 12-23-2019, 11:17 AM   #1
adileo
adileo's Avatar
Default 52 f1
Started truck today. Pulled out of garage and started to hear a clicking noise and clicking increases with RPMs. When I put clutch in noise goes away. Is that a bad throw out bearing? If not what could it be?
Thanks
Andy
1952 F1
adileo is offline   Reply With Quote
Old 12-23-2019, 06:55 PM   #2
1948F-1Pickup
1948F-1Pickup's Avatar
Default Re: 52 f1
With your foot off the clutch pedal, the clutch release bearing should be away from the "fingers" of the pressure plate...... so that shouldn't be the clicking.
1948F-1Pickup is offline   Reply With Quote
Old 12-23-2019, 07:19 PM   #3
adileo
adileo's Avatar
Default Re: 52 f1
Thanks but it is clicking/knocking with clutch released. Knocking goes away with clutch depressed.
Maybe tranny input shaft ball bearing?
Thanks
Andy
1952 F1
Old 12-24-2019, 07:09 AM   #4
ponymare
Default Re: 52 f1
Sounds like a transmission issue.
ponymare is offline   Reply With Quote
Old 12-24-2019, 07:51 AM   #5
chap52
chap52's Avatar
Default Re: 52 f1
The throw-out bearing would only be making noise as you depressed the clutch.
I found that the easiest way for this old guy (74) to pull a tranny in these is to remove the center transmission tunnel, disconnect the u-joint and slide the trans back, up and out. I even fabricated an extension for the arm on my engine hoist so I could come in through the passenger door and let the hoist do all the lifting.
Enjoy the adventure... Chap
chap52 is offline   Reply With Quote
Old 12-24-2019, 08:37 AM   #6
corvette8n
corvette8n's Avatar
Default Re: 52 f1
When I owned my '50, I had the ring gear get cockeyed on the flywheel it was hitting the block. I could not figure it out until I started to pull it apart. I was youn and foolish back then so I had the local farm store tack weld around the flywheel.
Old 12-28-2019, 06:09 PM   #7
1948F-1Pickup
Default Re: 52 f1
Tack welded ring gear. Wouldn't be the first time that's been done....
Old 12-28-2019, 06:16 PM   #8
adileo
adileo's Avatar
Default Re: 52 f1
It was above my skill level. Needs a complete tranny rebuild. While in there told mechanic do clutch.
Thanks
Andy
1952 F1
