10-26-2019, 01:47 PM | #1 |
Grease fitting caps
Doing brakes on a later model truck, of un-named heritage,
I found the bleeder screw had neat little caps protecting the hole. Happened to remember wanting to get the same cap for all my grease fittings; vehicles and machinery. Found 3 frozen this summer. A search showed 180 caps of M6,M8,M10 which I assume is the (metric) threaded portion of the fitting. All the fittings I have ever greased fit the same gun; so I am thinking these caps will work and if the hole in the retaining tab is too small,just cut it off. Can anyone confirm my assumption ??? Are you using something else ??? |
10-26-2019, 02:03 PM | #2 | |
Re: Grease fitting caps
10-26-2019, 02:17 PM | #3 |
10-26-2019, 03:31 PM | #4 |
Time to show off. Take your pick of caps.
https://www.ebay.com/sch/i.html?_fro...ps&_sacat=6000 Last edited by 19Fordy; 10-26-2019 at 03:38 PM. |
10-26-2019, 03:40 PM | #5 | |
10-26-2019, 04:51 PM | #6 |
