02-19-2014, 02:57 PM | #1 |
Brusegard upper steering column bushing/bearing?
Installed the Brusegard bearing/bushing in my '36 steering column tube many years ago and have since lost install instructions. Can anyone tell me the depth from the top of tube how far in the roller bearings should be. I think I may have installed it incorrectly and never tightened the set screws because I installed the roller bearings too deep.
02-19-2014, 03:28 PM | #2 |
Re: Brusegard upper steering column bushing/bearing?
The entire bearing and races should be in only about 1/8" in from the top when assembled. When installing the final piece get it down all the way and then bring it back up slightly. This will ensure there is no pressure on the bearing due to assembly. Tighten the two set screws using the short reach allen wrench supplied with the bearing.
02-19-2014, 04:19 PM | #3 | |
02-19-2014, 05:15 PM | #4 |
