07-08-2012, 01:21 PM | #1 |
Graphite rope seal "Questions"
Dear Friends!
I hope all of you be all right. I have to assembly my V8 1946 and i have some doubts. I must install the graphite rope in the U-shape as it is showed in the picture. My question is, 1)How long must the rope be in the upper and lower U-shape? 2)Must I make any threat such as put the rope in oil an entire day? avoid the dry rope against rotating metal? Please I hope you can understand what I mean, I need your advice. Thank you very much Harylufa
I love my Ford V8 1946! Harylufa! |
07-08-2012, 01:28 PM | #2 |
Re: Graphite rope seal "Questions"
Hary,
There should have been easy to follow instructions with your gasget set. It should contain an adjustable knife and a thickness guage that is "U" shaped which fits around the ends of your graphite seal. Once cut, it gives you the proper amount of rope sticking out past the flange. As for lubrication, the graphite already in the rope is the lube. Non-lubricated ropes can be soaked. Good luck with your build. Joe S.
Fat Fenders and Flatheads...doesn't get any better. |
07-08-2012, 05:01 PM | #3 | |
Look what I found in Youtube. It is exactly what I need to know. What do you think? https://www.youtube.com/watch?v=kSQWl...eature=related Thank you very much.
I love my Ford V8 1946! Harylufa! Last edited by Harylufa; 07-08-2012 at 05:47 PM. |
07-08-2012, 06:09 PM | #4 |
From gasket kit
GraphTite Rope Rear Main Seal Installation (general Instructions - not applicatuion specific) * This Graphtite rope seal is of proven, superior quality, however, careful attention must be paid when trimming to avoid fraying. * Do not pre-soak in oil * Press rope into place. Use a smooth rod, like a socket extension, to press in and compact rope to approximate the crankshaft seal journal diameter. * Trim rope about .015" beyond flush using spacer. Cut through rope and slightly into wood stick to ensure a clean cut. (stick, spacer, and knife provided) * Press protruding ends of rope down flush. Push any loose strands toward the center of rope end. Apply startup lube to rope surface. * Coat all cap to block mating surfaces with sealant. DO Not apply sealant on rope ends. Vergil
Bigger fonts to aid in reading |
07-09-2012, 07:43 PM | #5 | |
Ok, it is very interesting what you say, I think that I have not more questions. Thank for your help!!! Hary
