Old 04-22-2016, 09:51 AM   #141
itslow
itslow's Avatar
Default Re: Gravity bends a crank?
I got side-tracked at work one day and decided to ran a quick finite element analysis on a 5.7L SBC crankshaft to determine the amount of deflection that occurs when its stored in various orientations. The CAD geometry was simplified - features that would not affect the analysis were removed - to reduce processing time, but was taken directly from a GM-supplied model.
Four conditions were modeled, with gravitational force being the only force acting on the crankshaft. Steel with the following properties was selected as the material.
Things to note about the images:
  • Deformation measured/shown is only that in the direction of the gravitational force (downward in the images).
  • The colored bands help delineate the amount of deflection that is occurring in a particular region of the part.
  • The colored representation is over-scaled to help show the deflection of the part. It is not 1:1 scale.
  • The vertical (or horizontal) lines depict the original condition, unaffected by forces.
  • Units = Inch
Conditions Modeled:
  1. Vertical; Standing on flywheel flange
  2. Vertical; Hanging from flywheel flange
  3. Horizontal; Supported by all main journals
  4. Horizontal; Supported by only the front and back main journals
As you can see, even in the worst condition (vertical storage), the maximum amount of deflection that occurs is in the hundred thousandths. This is less than the accuracy that can be measured by nearly all micrometers. It would be fair to assume that a Flathead crankshaft would exhibit similar behavior.
So, in conclusion, store the crankshaft however you feel fit. If you want to store it vertically to save space, do that. If you want to store it horizontally to prevent damage from tipping over, do that.
Mike
Wanted:
- '32-34 Open Cab Pickup (RPU) parts and documents/articles/info
- ARDUN parts
itslow is offline   Reply With Quote
Old 04-22-2016, 09:54 AM   #142
itslow
itslow's Avatar
I also, for sh!ts and giggles, ran a simulation where the crankshaft is only supported by the center main journal. I'm not even sure how one would store a crank this way, but here's the plot:
In this case, you can see the max deflection is still in the ten thousandths.
Mike
Wanted:
- ARDUN parts
Old 04-22-2016, 10:29 AM   #143
rheltzel
rheltzel's Avatar
Hardly news...Molly's known this all along...she's seen straight crankshafts in every position imaginable.
rheltzel is offline   Reply With Quote
Old 04-22-2016, 10:41 AM   #144
Ronnie
Ronnie's Avatar
Yup
Ronnie is offline   Reply With Quote
Old 04-22-2016, 02:52 PM   #145
Prawbly
Prawbly's Avatar
Send a message via AIM to Prawbly
yup - therya go - real fart smellers
Prawbly is offline   Reply With Quote
Old 04-22-2016, 02:57 PM   #146
grovesmr
Originally Posted by uncle max View Post
I'm concerned now... Will climate change bend my crank?
Climate change encompasses too wide a collection of scenarios. Now magnetic pole flip, that will cause spontaneous separation of the molecular bonds, you will need to cryo and heat treat the crank when that happens
grovesmr is offline   Reply With Quote
Old 04-22-2016, 03:15 PM   #147
1952henry
1952henry's Avatar
Just you wait. That tidbit will be released to bring car guys into the fold.
"Nowwww letmebeclear. Ahhh, climatechange ahhhh, willbendyourcrank ahhh burnupyourcoil and ahhh ruinyourshocks. Thedebate ahhh isover!"
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
