12-17-2017, 10:01 AM | #1 |
Spark plugs/distributor tool
Back in the day, was there a special tool dedicated to the Model A for adjusting the distributor and spark plugs. If so can someone post a picture.
Thanks, Paul
http://MODELABASICS.com/ How Things Work on a Model "A" Ford Fordbarners, Feel free to use the pictures on my site to answer questions and create tutorials/tech articles. |
12-17-2017, 12:12 PM | #2 |
Re: Spark plugs/distributor tool
Would this be like a double-ended feeler gauge, with one end for point gap and the other end for plug gap?
12-17-2017, 12:18 PM | #3 |
A WORN Dime for the POINTS & a WORN Nickel for the PLUGS---They WORK!
Bill Gotchange?
12-17-2017, 12:40 PM | #4 |
Something similar to this.
http://MODELABASICS.com/ How Things Work on a Model "A" Ford Fordbarners, Feel free to use the pictures on my site to answer questions and create tutorials/tech articles. Last edited by 30ccpickup; 12-17-2017 at 12:49 PM. |
12-17-2017, 12:48 PM | #5 |
http://www.fordgarage.com/pages/krwfeelergauge.htm --from Vinces site
You don't see many of them, I have seen more combination machines, either they were too$$ (being Starret), or got lost |
12-17-2017, 01:44 PM | #6 |
12-17-2017, 01:57 PM | #7 |
And this is all you need for tune ups on a Model A! Once the initial timing is set at engine overhaul, head replacement or distributor R&R, it will not change until the engine is worn out. Just set the points to the proper gap and the timing will automatically be set, too. All this fiddling with special wrenches, etc. just serves to keep the owner out of the bars (if that's his hangup)!
12-17-2017, 02:41 PM | #8 |
Thanks, this falls under boys and toys. I collect things that relate to the Model A, as well as, restore distributor's.
http://MODELABASICS.com/ How Things Work on a Model "A" Ford Fordbarners, Feel free to use the pictures on my site to answer questions and create tutorials/tech articles. Last edited by 30ccpickup; 12-17-2017 at 02:46 PM. |
12-17-2017, 06:34 PM | #9 | |
Bill Missingtool
12-17-2017, 08:11 PM | #10 |
This one is marked points aligning tool.It was used for the Ford N series tractors.Pretty handy for any points though.
Thanks Keith. I have one of those and I always wondered where it was used. |
12-17-2017, 08:16 PM | #11 |
I'm not sure what the spring loaded sliding end on it does.It's been in my toolbox since the early 70's,and it was just in the last few days I found the writing on it.I never looked for it before.
12-18-2017, 09:26 PM | #12 | |
Bill Dontknoweither
12-19-2017, 09:29 AM | #13 | |
Bill Eagleeye
