04-04-2021, 11:34 AM | #1 |
Brain Fade!
Went to start my '41 PU yesterday - all went fine, except I got distracted and forgot to switch the ignition to ON. Cranked and cranked...battery was weak to begin with but I recovered my error too late.
Then put on the charger. Got the polarity correct but the negative clip was on the solenoid side of the battery disconnect clamp (that I had opened as part of the charge procedure) and I wondered for a bit why the charger indicated zero amps output? DUH! Relocated the neg clip to the battery post side and all was good. I just shook my head in disbelief and went to lunch. Can't win some days I guess Oh, yes, Happy Resurrection Day!
Alan 1929 Special Coupe 1941 Pick-Up 1955 Victoria |
04-04-2021, 12:06 PM | #2 |
Re: Brain Fade!
Normally, a guy would look around to see if anyone else noticed his blunder. At least you are comfortable enough post to the world just how dumb you can be. Ha Ha. Hope things go better after lunch.
04-04-2021, 12:24 PM | #3 |
Re: Brain Fade!
LOL...Was I 'Out to Lunch'?
04-04-2021, 07:30 PM | #4 |
Re: Brain Fade!
I'm glad I never did anything like that!
04-04-2021, 08:26 PM | #5 |
Re: Brain Fade!
I did almost the same thing with my 35 last spring. Forgot to turn on the battery cutoff saitch, went to the shop to get tools and the charger when i remembered the switch. Stuff happens
Sent from my SM-T550 using Tapatalk |
04-05-2021, 12:16 PM | #6 |
Re: Brain Fade!
04-06-2021, 01:03 AM | #7 |
Re: Brain Fade!
"spring fever"
GB
"you can't make honey out of dog sh*t" "You're a long time looking at the lid" |
04-06-2021, 08:53 AM | #8 |
Re: Brain Fade!
04-06-2021, 01:39 PM | #9 |
Re: Brain Fade!
I have the same problem. My Doctor diagnosed it as CRS Syndrome...Can't Remember Shit !!
04-06-2021, 03:19 PM | #10 |
Re: Brain Fade!
And when you build a fresh engine and put it in the recipient vehicle, don't forget to put some oil in it. Don't ask why I mention this.
04-06-2021, 03:54 PM | #11 |
Re: Brain Fade!
I’ve a “friend” who routinely makes great double flares when making up brake lines. My “friend “ has routinely tossed the lines after making the length perfect. My “friend “ does forget to put the fitting on the line first.
I still like me though. |
04-06-2021, 04:26 PM | #12 |
Re: Brain Fade!
Any of you guys changed the oil, then poured in the new oil - without refitting the drain plug first?! I was 16 when that first happened to me...never did it again. My dad was pissed...all over the clean garage floor!
Alan 1929 Special Coupe 1941 Pick-Up 1955 Victoria Last edited by Anteek29; 04-06-2021 at 04:36 PM. |
04-06-2021, 05:33 PM | #13 |
Re: Brain Fade!
Took my newly restored 35 coupe to a car show, parked-got out-walked away about 20 feet- some one yelled your car is on fire. shure enough the whole wiring harness was red hot and burning.grabbed a set of wire cutters and cut most of the wireing harness in two. Stepped back and wondered why I didn't turn the battery disconect switch off under the seat
04-06-2021, 05:51 PM | #14 |
Re: Brain Fade!
Remember the t v show Hee Haw.....and the song ...If it weren't for bad luck, i'd have no luck at all. Gloom despair.........keep smiling......!
04-06-2021, 10:47 PM | #15 |
Re: Brain Fade!
Please do not go to the H.A.M.B. and check out the thread entitled : "What's the dumbest thing you ever did to your vehicle while working on it?".
Thank you. |
04-06-2021, 10:55 PM | #16 |
Re: Brain Fade!
Yes Autumn here ( or as you northern folk say "Fall") and getting cooler
GB
04-06-2021, 10:56 PM | #17 | |
Re: Brain Fade!
GB
04-06-2021, 11:10 PM | #18 |
Re: Brain Fade!
Smoked a original yellow top coil when I had a yblock on the stand. Left the switch on. It happens.
https://www.youtube.com/watch?v=edmqTODMZC4 . |
