Old 11-01-2019, 05:07 PM   #1
ford31
ford31's Avatar
Default model a radiator
what advantage is preasure cap on model a ford seen it couple times now
ford31 is offline   Reply With Quote
Old 11-01-2019, 09:22 PM   #2
Mike V. Florida
Mike V. Florida's Avatar
Default Re: model a radiator
On a stock radiator, not a thing.
Old 11-01-2019, 10:27 PM   #3
30 Closed Cab PU
Some have converted to a pressurized system by buying a pressurized radiator. I know very little about them, but if they allow higher coolant temps, the A is not really designed for higher coolant temps near or above boiling (212).
Old 11-02-2019, 03:07 PM   #4
woofa.express
woofa.express's Avatar
Hi ford 31. I installed a pressurised radiator and I am having trouble with it to the extent I regret it. Water will flow out, just like it should but the seal sitting on the neck prevents it returning. I would do away with it but the radiator top tank is partitioned off and that in addition reduces the radiator capacity. In anticipation of the pressure causing leakage around the water pump I installed the new sealed pump and that is good. cheers, gary
I know many things,
But I don't know everything,
Sometimes I forget things.
And there are times when I have a long memory.
woofa.express is offline   Reply With Quote
Old 11-02-2019, 04:52 PM   #5
fastroadster
They do it to raise the boiling point....... Don't really have to on a Model A
fastroadster is offline   Reply With Quote
