Old 04-05-2016, 12:36 PM   #21
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Default Re: Transmission/Gears/Animation
It's interesting to study the power flow through the trans. With a trans on the bench & the shift tower OFF, you can shift it into each gear, turn it, & study the FLOW. Then, you discover that the shift rails/forks, move in the OPPOSITE direction of the shift lever! Understanding this stuff helps, when you're doing "ARMCHAIR" diagnosis of a trans problem.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 05-22-2016, 09:39 AM   #22
Mitch//pa
A suggestion,,,
have the ratio listed when your in each gear
Old 05-22-2016, 10:56 AM   #23
Al 29Tudor
Al 29Tudor's Avatar
Originally Posted by aermotor View Post
Great - although a little fast for my slow brain and tired eyes.
John
I ran it many times in stop mode - then you can select different positions on the bar at the bottom and study any gear selection.
Great utube clip - very educational.
Thank you.
Al
Al 29Tudor is offline   Reply With Quote
Old 05-28-2016, 10:43 PM   #24
oldbike99
oldbike99's Avatar
Very nicely done. I like your work.
oldbike99 is offline   Reply With Quote
Old 05-29-2016, 06:34 AM   #25
mshmodela
mshmodela's Avatar
Once more, very nicely done... Thank you so very much!
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 05-29-2016, 06:59 AM   #26
JRShaw
JRShaw's Avatar
Smile Re: Transmission/Gears/Animation
Mike - I think that this is an excellent idea, and would be of great value for many of us. Keep up the good animation work!!
Joel R. Shaw
Late '31 Pickup & 1/2 Late '31 Roadster
JRShaw is offline   Reply With Quote
Old 05-29-2016, 08:46 AM   #27
apbright
apbright's Avatar
- Animate the motions of the shifter and the gears (show their sliding movement; should be possible, in e.g. Solidworks, don't know which SW you're using)
- Add colour codings to other gears as well (e.g. the cluster gear, reverse idler gear, etc.)
- Before showing the shiftings, introduce each of the critical parts with flash-up text (each of the gears, the forks, etc.)
- Add rotational animation of the input, output shafts and the gears
Nice to see modern technology applied to our old hobby. I'm still waiting for the day when solid model / *.stp files are available for all Model A parts. If it's still not done when I retire (20 years?), maybe that's what I'll do.
Great work!
apbright is offline   Reply With Quote
Old 05-29-2016, 09:28 AM   #28
taffrail
taffrail's Avatar
Great video, I now understand why the shift lever ball should be round and not almost square like mine !
taffrail is offline   Reply With Quote
