Old 09-26-2021, 02:56 PM   #1
skeazle
Default water pump
At last I got my gas leak fixed. Now all I have left to fix is the leak at my water pump. I have the new style with the false grease fitting and I am pretty sure mine has the stud and nut all in one so there should be more room to pull off the pump right? I have over an inch clearance between my fan blade nut and the fins of the radiator. Would that be sufficient enough to pull away the old pump? Is this a job I could do myself?
skeazle is offline   Reply With Quote
Old 09-26-2021, 03:08 PM   #2
midgetracer
midgetracer's Avatar
Default Re: water pump
If you have the 2 blade fan, you could release the radiator rods and tip the radiator ahead far enough to remove the water pump. It would help to remove the hood. You should be able to do this task yourself.
midgetracer is offline   Reply With Quote
Old 09-26-2021, 04:05 PM   #3
skeazle
Thanks. I'll give it a try.
Old 09-26-2021, 06:10 PM   #4
Synchro909
Synchro909's Avatar
If you have a 2 blade fan, place the blades vertically and take the pump out to the side. You don't need as much room that way.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 09-26-2021, 07:37 PM   #5
nkaminar
nkaminar's Avatar
The hood on my 1930 car is a little heavy to lift. I can do it but it is a hassle. Others have rigged blocks and tackle and a hook on the ceiling to lift the hood up. The block and tackle used to store bicycles may do the job. I put a carpet down on the cement floor to store the hood vertically so that the paint does not get chipped or the hood distorted.
