Old 09-26-2021, 04:17 AM   #1
Oberfranke
Oberfranke's Avatar
Default Turn signal beeper or other solutions
Increasingly with age, I sometimes forget to turn the turn signal off again. Sometimes this creates dangerous situations.
How have you solved this? I have the turn signal kit (6V). In the catalog there is a turn signal beeper. How should it be connected and installed?
Maybe there are other solutions?
Greetings from Bavaria.
Oberfranke is offline   Reply With Quote
Old 09-26-2021, 04:26 AM   #2
Oberfranke
Oberfranke's Avatar
Default Re: Turn signal beeper or other solutions
Old 09-26-2021, 04:27 AM   #3
bavArian
bavArian's Avatar
Hallo Nachbar,
you usually have a turn signal lamp in your turn signal switch. From there you can get -6V and wire that to the signal beeper. That way the beeper sounds every time any of the turn signals is on.
Have a nice day, (and go vote today )
Daniel
EDIT: Only saw that picture after my post. Is it 1 lamp or 3 independent lamps?
bavArian is offline   Reply With Quote
Old 09-26-2021, 06:08 AM   #4
Patrick L.
Patrick L.'s Avatar
I understand, the lights are hard to see at times. The 'beepers' I'm aware of are plug-n-play, they just replace the flasher.
I install the unit so the stalk is in line with a steering wheel spoke. If I can see the stalk after a turn I know I've left the light on once again.
Old 09-26-2021, 06:43 AM   #5
Werner
Werner's Avatar
I have the same forgetfulness problem.
I don't like an electronic beeper in this car. So I soldered a small clapper to an old relay on its anchor. This relay gets its impulse directly from the flasher relay. It sticks to the firewall sheet with a magnet. At the blinking signal, there is an eager and clearly audible knock against it.
Gruesse aus'm Rheinland.
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 09-26-2021, 07:03 AM   #6
nkaminar
nkaminar's Avatar
My hearing is such that I cannot hear a beeper. The lights that come on on the unit when the flasher is on did not show up very well in my unit, the same one you have. So I wired the indicator lights on the unit to the flasher relay and now they are bright. The only problem is that the light in the center is on all the time but a bit of black electrical tape solved that problem.
Old 09-26-2021, 07:48 AM   #7
Patrick L.
Patrick L.'s Avatar
Thats a pretty slick idea !
Old 09-26-2021, 03:04 PM   #8
Herb Concord Ca
If your flasher is a 3 terminal type, connect the beeper to the P terminal on the flasher, other wire to ground. May have to reverse the wires for it to beep.
Herb Concord Ca is offline   Reply With Quote
Old 09-26-2021, 06:13 PM   #9
Synchro909
Synchro909's Avatar
IMO, when a driver has a beeper on the turn signals, it sounds like the car is going to back-up.
Old 09-26-2021, 07:06 PM   #10
[email protected]
modela@aol.com's Avatar
https://www.amazon.com/dp/B07QBP1W5L...SE7F4XNQMV5RYH
Super cheap and loud buzzers. If too loud put a piece of tape over the sound hole. Two leads that can be attached to the two main flasher relay terminals…. Give the extras to other Model A owners you see with a constant turn signal flash going down the road….
modela@aol.com is offline   Reply With Quote
Old 09-26-2021, 08:24 PM   #11
1crosscut
1crosscut's Avatar
I picked up two small led bulbs from Radio Shack, one green for starboard and one red for port. Right and left for you landlubbers.
I ran a couple of small gauge wires that are tied into the turn signal circuits up to the inside of the left front corner of the roof. Tucked up and out of the way but easy to spot when they are activated. My signals have a beeper but my hearing isn't as good as it used to be so the indicator lights have been very handy.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 09-26-2021, 09:05 PM   #12
wwirz
I installed the Logo Lites directionals and I love them.
wwirz is offline   Reply With Quote
Old 09-27-2021, 09:59 AM   #13
katy
katy's Avatar
I use the flasher w/the built in beeper. Works for me.
Old 09-27-2021, 10:36 AM   #14
SSsssteamer
SSsssteamer's Avatar
Ditto
SSsssteamer is offline   Reply With Quote
Old 09-27-2021, 11:07 AM   #15
Mister Moose
Mister Moose's Avatar
Since I don't drive looking down the steering column for the dimmest indicator lights in the world, I wired a cheap Radio Shack beeper to the turn signal. It's invisible and functional.
Mister Moose is offline   Reply With Quote
Old 09-27-2021, 06:46 PM   #16
NZ28ModelA
NZ28ModelA's Avatar
How about wiring a small electric shock through the seat base??
NZ28ModelA is offline   Reply With Quote
Old 09-27-2021, 08:16 PM   #17
Y-Blockhead
Y-Blockhead's Avatar
I drilled a hole thru one of the dash rail screws and installed a green 3mm LED. Hard to ignore that flashing green light...
Old 09-28-2021, 11:56 AM   #18
katy
katy's Avatar
What does that do to pacemakers?
Old 09-28-2021, 05:28 PM   #19
eagle
eagle's Avatar
Use a beeper of any kind that will work on 6 Volt. Lots of them on amazon or ebay for a couple bucks. Wire it ACROSS the normally closed flasher contacts. Make sure the polarity is correct.
Old 09-28-2021, 05:39 PM   #20
Oldgearz
Do as Herb said. Red wire on mine is ground and black to "P" terminal. Wires are very thin. The beeping noise is high pitched and slightly annoying, but I find it better to be safe and slightly annoyed than dead and calm.
Oldgearz is offline   Reply With Quote
