09-17-2012, 01:06 PM | #1 |
AA u joint help!
I need the help of all the gurus out there. I'm working on an early 30 AA and at some point in its life a long time ago it lost one of its u joint caps and has been driven ever sine bangin and clangin away. Now I would like to fix this problem but cannot seem to find anyone selling a new AA u joint assembly. So my question is will the A7090 u joint assembly sold fit the AA?
09-17-2012, 01:18 PM | #2 |
Re: AA u joint help!
If it is like this one give me a call this evening. Rod
http://www.fordbarn.com/forum/showth...ighlight=joint 308-529-2467
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!! Last edited by Rowdy; 09-17-2012 at 02:27 PM. |
09-17-2012, 01:39 PM | #3 |
AA's don't need no stinkin' caps! Don't need no stinkin' grease either! |
09-17-2012, 01:48 PM | #4 |
Haha nice Tom. The one I'm working on has the small circlips to hold the u joint in, or at least its supposed to.
09-17-2012, 02:18 PM | #5 |
Does it look similar to this one?
Bob |
09-17-2012, 02:22 PM | #6 |
09-17-2012, 02:28 PM | #7 |
Forgot the link the first time, but editted it in. Rod
09-17-2012, 02:40 PM | #8 |
That's the right design Rod but the wrong spline count. This one I need is 10 in and 10 out.
09-17-2012, 02:47 PM | #9 |
The one Rowdy that I saw is 10X10.
09-17-2012, 02:51 PM | #10 |
Ok, so you have a 3 speed or the longer wheel base truck then. Rod
09-17-2012, 02:56 PM | #11 |
The a-7090 u-joint is for the model A car, the truck u-joints are not supplied by the vendors, I assume the one you need is between the coupling shaft and the rear drive shaft? and normally is a 10-10 spline joint which you can see in Rowdys pics page 11.
Here is a pic of the 3 I had, the one on the left is the one I think you need, if not post a pic of the one you need. |
09-17-2012, 03:10 PM | #12 |
Simular to this one which I was told was for a 1938 or later. Rod
09-17-2012, 03:54 PM | #13 |
The AA has 1 1/4" drive line and the BB is 1 3/8". Most of the BB and later u-joints I have
seen have needle bearings. Bob |
09-17-2012, 04:17 PM | #14 |
Rod that last one you put up looks like it!
09-17-2012, 04:41 PM | #15 |
I will see if it is still here in the shop or if I took it back out at the farm. Looks like will be spending the evening in the shop. As Bob pointed out the size difference I will measure this one to make sure it is not the flathead era U-joint. Rod
09-17-2012, 05:27 PM | #16 |
The one I have is 1 1/4" on both ends
09-17-2012, 05:34 PM | #17 |
Brian T, the one on the left is the one I need.
09-17-2012, 06:16 PM | #18 |
I found it in the shop and this one is 1 3/8". Rod
09-17-2012, 07:04 PM | #19 |
Jon,
I purchased one for my AA from B & B model a parts in nj. Not sure if he is still in business. Another source is Bert's Model A parts in Co. Mike |
09-17-2012, 08:26 PM | #20 |
Thanks Mike, I'm gonna call Bert's tomorrow and see if I can locate this B & B
