02-25-2012, 09:07 PM | #1 |
model b water pump adapter
would anyone be interested in a model b water pump with adapter to a model a head?
02-26-2012, 01:52 PM | #2 |
Re: model b water pump adapter
This would be rare, it is more likely to be an early V8 pump adapter. They look similar but the V8 has a smaller bolt "circle" than the B pump.
02-26-2012, 02:05 PM | #3 | |
Charlie Stephens |
02-27-2012, 12:29 PM | #4 |
I'll see if I can post pictures of it when I'm home from work, I believe the crankpulley is different than standard A.
02-27-2012, 07:20 PM | #5 |
02-27-2012, 07:37 PM | #6 |
J K, I would be interested to know how the fan is attached to that water pump pulley? Thanks Manuel in Oz |
02-27-2012, 07:40 PM | #7 |
I believe it bolts on similar to the way the fan bolts to the generator of a 32
02-27-2012, 09:36 PM | #8 |
02-27-2012, 11:07 PM | #9 |
The head is a stock A with a block off plate over the standard upper outlet.
02-28-2012, 09:56 AM | #10 |
Will that fit behind the radiator in a stock configuration??
Paul in CT |
02-28-2012, 10:43 AM | #11 |
The V8 pump is short, and normally these adaptors are designed to put them in line with the crank pulley. An unaltered v8 pump would have no place for a fan, though I think one would fit if the pulley had a means of mounting it.
02-28-2012, 05:13 PM | #12 |
It looks like it may fit behind the radiator but it would be veeery close. It was run on an a coupe race car so I'm assuming it fit.
02-28-2012, 07:00 PM | #13 |
Turns out you can buy the adapter from MACS for $59.95. This one has the Ansen name cast on the side so its not one of the modern repops.
02-28-2012, 07:10 PM | #14 |
I was browsing thru a Mac's catalog today and saw it. Interesting thread on the EV8 forum about Mac's and its shipping.
Paul in CT |
02-29-2012, 08:34 AM | #15 |
I was part of that thread. Not to change the direction of this one but I'm a parts dealer for Macs and have never had a problem with them.
11-01-2013, 12:44 PM | #16 |
Do you guys know where to get the model a radiator to model b v8 waterpumop hose? the A is larger... thank you!
11-01-2013, 12:50 PM | #17 |
I have a model B 4 cyl head to a model a radiator..
11-01-2013, 01:31 PM | #18 |
You can go to the local parts store and look through the hoses. I did that last week trying to find a 2" hose to adapt a homemade coolant filter I have in mind. These days there aren't many cars still using a 2" hose, so my selection was very limited. If you do an ebay search you can look for 2" radiator hose or 2" straight hose and find quite a few with 2" on one end and a different size on the other end.
11-01-2013, 01:45 PM | #19 |
Jon,
I have the same set up up in my attic alum. head with block off plate, waterpump and adapter, alum. side cover and hot cam mike not for sale |
