Old 12-20-2012, 09:48 PM   #1
Double Trouble
Default Double A cab trouble
I'm trying to figure out how to replace the channel that was originally formed onto the top edge of the back of a model AA truck cab.
Mine was butchered in a botched "restoration"attempt.
Would it be possible to roll this as a channel or could I weld a couple of flanges together?
Is there anyone that could fabricate this"channel"? for me?
the photo on the left is what I have to work with, the other is what I am trying to reproduce as a weld in "patch panel"
Double Trouble is offline   Reply With Quote
Old 12-20-2012, 09:54 PM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Double A cab trouble
Send me some pix via email with a lot more detail so I can see exactly what you are needing.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 12-20-2012, 10:11 PM   #3
Bob C
I don't see anything wrong if you are asking about the end where it curves, this is what mine looks like.
Bob
Old 12-20-2012, 11:59 PM   #4
Double Trouble
Thanks for posting that photo, I only wish mine looked that good, My cab is welded together and is missing the whole top nailing flange and trim channel. The other photo I posted was meant as an example of what I hope to come up with in the way of a patch panel (barring a donor cab back) I should have mentioned that in my post.I'll try to edit it
Old 12-21-2012, 06:13 AM   #5
BRENT in 10-uh-C
That is why pictures would be a great help for us to offer advice. If it is missing what I susppect,, then going to a local sheetmetal shop and have them double brake a flange that can be welded on would probably be easiest.
BRENT in 10-uh-C
Old 12-21-2012, 11:31 AM   #6
Double Trouble
I didn't know it was possible to form a channel like that on a brake, thanks Brent for the advice I'll see what I can come up with locally.
see Bob's reply for a photo of his flange/channel edge I'm talking about.
John
Old 12-21-2012, 09:26 PM   #7
j0eitall
They sell the top pannels ill find them and pm you tomorrow with the link .
j0eitall is offline   Reply With Quote
Old 12-23-2012, 12:11 AM   #8
Double Trouble
I've got the panels that go over the door(not the welded-in home made ones in my first photo)between the visor and the shell back, it's whole nailing flange from rain gutter to rain gutter I'm looking for
thanks just the same.
Old 12-25-2012, 08:14 AM   #9
29closedcab
You have the option of using a set of step beading dies in a bead roller then use a Shrinker to shrink the metal to get the arc that the roof has. Then weld the pieces together
29closedcab is offline   Reply With Quote
