06-09-2018, 05:35 AM | #1 |
6 volt electric radiator fan
Does anyone know who sells an 6 volt electric radiator fan that you mount on front of radiator. Can many 12 volt but no 6 volt. It is for 1953 Ford.
06-09-2018, 07:43 AM | #2 |
Re: 6 volt electric radiator fan
You could possibly use a heater fan motor from the car since it would be 6 volt and easily attainable.
06-09-2018, 08:01 AM | #3 | |
Unfortunately, a heater motor isn't going to have the torque necessary to move the mass of a radiator-type fan. DD |
06-09-2018, 09:23 AM | #4 |
Donald,
There are several vendors that offer 6 volt fans. Speedway, Summit, Jegs etc. Just google "6 volt electric radiator cooling fans." For installation on my '53 Crestline victoria, it was necessary to loosen the mounting bolts, so I could angle the the radiator rearward, to gain clearnace to position the fan. One other comment. The front mounted fan did not provide enough cooling by itself in warm weather. A rear mounted fan is better. Best is the original fan. Richard
twodeuces |
06-09-2018, 01:06 PM | #5 |
If you run an electric fan you better find a 6 volt alternator
that charges at idle speeds. G.M.
www.fordcollector.com |
06-09-2018, 03:20 PM | #6 |
