05-31-2016, 10:12 AM | #1 |
L100 cam with original lifters?
The rebuild of my 8ba will likely include the L100 cam. I am hoping to use the original lifters. However, I expect that the L100 regrind will have reduced the dimension of the base circle. I figure this will increase the clearance between the lifters and the original valves.(?)
So, if my thinking is correct, it may be advantageous to get a set of Chevy valves; perhaps their 0.100" great length may allow for a satisfactory arrangement (butt grinding.) Or, switch to adjustable lifters and retain the original valves. Anybody have experience with this? Thanks. Richard
twodeuces |
05-31-2016, 10:41 AM | #2 |
Re: L100 cam with original lifters?
If your valvetrain is good you can always add lashcaps to get some added lenght of the valves.
06-01-2016, 07:04 PM | #3 |
.............. just my humble opinion, but I would treat that new L100 bump stick to a new set of quality adjustable lifters. Others may differ, just my .02 cents.
I went, I saw, I bought the T shirt 51 Ford Deluxe Tudor 32 Ford roadster 39 Mercury Towncar |
06-01-2016, 07:42 PM | #4 |
New lifters always with new cam is my rule.
06-01-2016, 08:06 PM | #5 |
You could use the old lifters, but they should be reconditioned as a minimum.
06-01-2016, 09:20 PM | #6 |
"The 1007B has something none of those other cams have. A higher rate of lift. This equals more mid range power where you need it with a street engine." Lonnie |
06-01-2016, 10:11 PM | #7 |
There is one thing you have to understand about an L-100 cam. It is a dual pattern cam, intake 246 @.050 and ex 235 @ .o5o" and 360 net lift. When I first saw this I doubted it could be driven on the street in a heavy vehicle. However, the engine was installed in a 5500 lb ambulance. That was sometime in the late 80's and I became a believer ever since. The Isky 1007B is a very good cam, unfortunately, theonly way to prove one way or another which cam was the best would be very difficult. I've run them both.
06-02-2016, 08:16 AM | #8 |
I also use chevy valves with the L-100, as they're .060" longer and keep the adj lifter, less likely to loosen.
