06-28-2013, 03:22 PM | #1 |
Extending tail pipe to rear of car
I have a 31 sw with AC . The condenser for the AC unit hangs from the bottom of the body behind the rear end not to far from the end of the exhaust pipe . I would like to extend the exhaust pipe past the condenser . Any one have any tips on doing this .
Thanks for all responses. |
06-28-2013, 03:28 PM | #2 |
Re: Extending tail pipe to rear of car
Some vendors offer an "extension" for a station wagon that might work, or visit a muffler shop that "bends" their own. FWIW
Paul in CT |
06-28-2013, 06:54 PM | #3 |
Small world, just did that last week. Had a muffler shop bend it for me. Hopefully the turndown may help keep some exhaust film off the chrome, too. It's not as close to the ground as it looks....
06-28-2013, 08:19 PM | #4 |
the extension for the station wagon requires you to cut the tail pipe at the muffler. It comes out dead center of the back of the car. It requires a special mount (included) that bolts to the passenger side spring bar. You should check first to see if it will interfere with your condenser. I would go to a muffler shop and have it custom made, probably cheaper too.
06-28-2013, 09:49 PM | #5 |
Genlemen ;
Thanks for the response . Trying to get as much heat as possible away from the condenser . Kingbee , did you look at routing the exhaust extension over the axle housing ? |
06-28-2013, 10:47 PM | #6 |
06-29-2013, 08:14 AM | #7 |
Why did Henry engineer the tail pipe to stop so far under the car anyway?
06-29-2013, 08:49 AM | #8 |
One thought is ease of maintenance. The longer pipe cannot be removed without putting the car on a lift if it was a one-piece unit. Another thought is the extra 15 cents it might have cost.
