Old 09-26-2021, 02:54 PM   #1
third_edition
third_edition's Avatar
Default 39 Pickup Cab Mounting
Hi All,
Does anyone have pictures of the correct way to mount a 39 Pickup Cab to the frame?
I bought the correct wood (which seems to fit properly to the bottom of the cab) and I bought the bolt kit from Ray N.
I am interested in any additional insulation that was used and the orientation / number of washers & springs.
Thanks,
George
third_edition is offline   Reply With Quote
Old 09-26-2021, 04:26 PM   #2
1939mars
1939mars's Avatar
Default Re: 39 Pickup Cab Mounting
Hopefully these will help
1939mars is offline   Reply With Quote
Old 09-26-2021, 09:02 PM   #3
Tinker
Tinker's Avatar
Only thing is frame welping that was stapled to the wood. Model A same as 39 in bulk.
Also depending on access to the correct bolts, old valve springs can double as front cab springs. Use castle nots/bolts to ensure they stay in place. At the very least nyla-nuts.
If you bought a complete set of bolts you have everything you need. But ask and post your pictures if you are uncertain.
Old 12-01-2021, 09:36 AM   #4
third_edition
Just out of curiosity, some of the bolts (in the center of the cab) have no springs while the bolts at either end have springs. How is this supposed to work? I would have thought solid throughout or springed throughout.
George
Old 12-01-2021, 04:28 PM   #5
GaryU.
GaryU.'s Avatar
My '39 pickup had that, no springs in center, just on the out side mounts. This was an original pickup that had never been apart before. From Grandparents farm and in my family since 1947.
GaryU. is offline   Reply With Quote
Old 12-01-2021, 10:15 PM   #6
Tinker
Tinker's Avatar
Same also. Probably for frame flex. Frames move/twist around. A couple parallel points of solid bolts the and the rest for flex. Not sure the body could take a solid bolt down to the frame. Maybe the reason pre unibody cars have body biscuits (or rubber pads) Just my thought. I'm sure they did it for a reason.
Old 12-02-2021, 09:25 AM   #7
38bill
38bill's Avatar
Been driving my truck for 20+ years with the cab bolted solid to the frame with no issues. Of course I'm always running with a light load and on good roads. Not like the working trucks in their day.
38bill is offline   Reply With Quote
