Old 12-02-2021, 11:03 PM   #1
Jwawhite
Jwawhite's Avatar
Default Speedometer Won't Zero
My speedometer will not return to zero mph unless I travel in reverse for a bit.
Any suggestions?
Jwawhite is offline   Reply With Quote
Old 12-03-2021, 04:46 AM   #2
KULTULZ
KULTULZ's Avatar
Arrow Re: Speedometer Won't Zero
If it zeros in reverse, most likely the speedometer head needs cleaning and lubrication.
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 12-03-2021, 12:19 PM   #3
rotorwrench
rotorwrench's Avatar
Default Re: Speedometer Won't Zero
The old Ford units last relatively well over long periods of time but all of them need some lubrication now and then. Some have a tiny plug near the drive input that can be removed to apply a light oil to the wick inside but it is mostly for the magnet drive bearings. The magnetic drag cup bearings generally just need to be clean and free of corrosion or other contaminants. Not all speedometers are made the same so I can't give you much more information than that. The drag cup clock spring can eventually lose some of its tension but is usually adjustable for unit calibration.
The drag cup is connected to the needle and the magnet that is connected to the drive runs inside of the drag cup so the two assemblies have different bearings. If the magnet shaft bearing wear too much, the drag cup will eventually stick to the magnet. It makes a hell of a racket and generally ruins the clock spring that returns the needle to zero when that happens.
Old 12-06-2021, 12:08 PM   #4
papanick
Yes it will need to be serviced and cleaned.
papanick is offline   Reply With Quote
