01-16-2022, 11:16 AM | #1 |
All-weather car cover suggestions
Looking for a quality, all-weather, durable car cover for my '40 2 door sedan. Unfortunately, my car is being stored outdoors under a steel carport for the time being. Cheap, light-duty covers just don't do the job as well as I would like, so hoping to get some feedback from others about other options. The main criteria is that it be as WATERPROOF as possible.
Thanks to all. |
01-16-2022, 11:55 AM | #2 |
Re: All-weather car cover suggestions
I'd like to offer my .02¢ here... while storing your car outdoors is problematic in itself, covering it can easily compound the inherent issues.
Trapping moisture beneath the cover is far worse than allowing the car to be exposed and breathe naturally. If you can keep the sun off of your car, that's perhaps the best thing to be done. Water and snow won't hurt the car very noticeably. Trapping moisture will cause damage. The cover moving due to wind will most certainly scuff paint.
01-16-2022, 12:08 PM | #3 |
Would it be possible to buy some 1x4 lumber and using sheetrock type screws, fasten 3 or four canvas tarps around the perimeter? If they don't go all the way to the ground, that's ok too. I have a metal carport that was open on four sides, but made a wall on the windward side. Here our damp weather comes mostly from the same direction, so one wall works quite well. I would stay away from cheap plastic tarps for many reasons. Tractor supply and others sell treated, tan colored real canvas tarps.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
01-16-2022, 12:24 PM | #4 |
Years ago a buddy made a cover for his ski boat using emt fittings and pipe and a silver heavy duty tarp tarp. Secret was to keep it small enough to cover the boat but not so high so the wind has less of a chance to get under it and blow it into the neighbors yard. He used cement filled 5 gallon buckets for anchor weights.
Making the simple complicated for over 30 years. |
01-16-2022, 12:34 PM | #5 |
I certainly have some good feedback to think about - some options I hadn't considered. Appreciate all the replies.
01-16-2022, 01:24 PM | #6 |
01-16-2022, 01:42 PM | #7 |
I have had several Cal car covers. My cars were stored outdoors in Socal, and indoors in the high dessert. Noah is my choice fabric.
Bruce
Works good Lasts long time |
01-16-2022, 02:19 PM | #8 |
If your car is outdoors on the bare ground, be sure to place cover the ground where it sits with a large piece of plastic to act as a moisture barrier so evaporating water won't rise up and rust the underside of the car.
01-16-2022, 02:49 PM | #9 |
If you decide to go with a car cover, by all means DO NOT go anywhere near "Sealskin" company ! You will regret it the rest of your life !
01-16-2022, 04:06 PM | #10 |
In my case the cover invited mice. Jack.
01-16-2022, 06:13 PM | #11 |
California Car cover is by far the best choice. You will find they offer a light weight water repelling cover that's outstanding. Its not cheap in cost but its well worth the protection your looking for.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
01-16-2022, 10:26 PM | #12 |
There is no alternative for fully enclosed
climate controlled storage for any vehicle you value. Any waterproof cover will not allow ground moisture to naturally evaporate and promote mold - mildew - rust. Any car cover will rub the paint off. I don’t put car covers on vehicles I transport in my enclosed trailer for that reason. An inflatable fully enclosed cover requires electricity to keep it inflated - and - depending on the amount of rain or snow you get - will not really last. Either rent a space or build one … 💡 Jim |
01-17-2022, 07:58 AM | #13 | |
This is spot on! Also, if the website does not answer ALL your questions, pick up the phone & call them! They have great customers service reps who are car guys as well. The times I have called over the years, they were always willing to take the time to answer fully! Outdoor covers from a Quality company like California Car Covers are made specifically to address issues that the consumer would face when storing their collector cars outside. Moisture wicks away quickly & mold is non existent. Ground moisture is no more of an issue than parking the car outside uncovered, because the cover does NOT stop air flow below the car. Quality covers are Make/Model specific, are custom fitted with elastic front & back with a cable under the center to keep wind from getting under the cover. Just like everything else.....You Get What You Pay For! God Bless Bill https://www.jalopyjournal.com/forum/...closed.614419/
Your QUALITY Ford Barn Transporter- Open or Enclosed. Bill's Auto Works Est. 1983 & Still Going Strong! 1955 Chevy Altered W.B. Gasser 1955 Nash Amb. Cust. Lemans 1957 Pontiac Chieftain 2 DR HT 1964 Pontiac Grand Prix 2 DR HT 1966 Pontiac Catalina Conv 1966 AMC Ambassador DPL 2 DR HT 1966 AMC Ambassador Cust 2DR HT 1967 AMC Marlin 1967 Toronado 1973 Chevy Nova Full Chassis Car 1992 Jag XJS Conv 1992 Jag XJS 2 DR Coupe 2007 Cadillac XLR-V Supercharged Roadster Last edited by Bill's Auto Works; 01-17-2022 at 09:00 AM. |
