Old 05-17-2022, 07:23 AM   #1
dad's deuce roadster
dad's deuce roadster's Avatar
Default tricks to getting the drive pulley off the crank
Trying to get the pulley off the crank. Quite a bit of load on the puller so far without movement. Have heated it some but no luck so far. Any tricks other than just keep going? I have in the past simply added a little more turn any time I happen to walk by while working on other projects and to quote Red from the Shawshank Redemption, "That's all it really takes, time and pressure".
dad's deuce roadster is offline   Reply With Quote
