12-20-2021, 12:59 AM | #1 |
Fuel pump ID
I was trying to help a fellow Barner for a fuel pump and found this. The only markings on it are an "H" and the number "35" surrounded by a cryptic looking radii pattern. Cast in the top plate is "PAT PENDING MADE IN USA". Anyone have an inkling of an idea what it is/fits?
Tom Last edited by tomcarman; 12-20-2021 at 01:05 AM. |
12-20-2021, 01:28 AM | #2 |
Re: Fuel pump ID
Flathead V8 '35-'48.Wiil work on 1934 but the '34's have a smaller top 1/2 casting.Very common.
12-20-2021, 01:32 AM | #3 | |
Re: Fuel pump ID
12-20-2021, 08:09 AM | #4 |
Re: Fuel pump ID
Looks like a post war aftermarket replacement made by Holley thus the "H"and the radial date code. For Ford production, in about 36 the top white metal casting was increased in size from the early 34-36 pumps. None of the 34-40 pumps have the pressed steel top with the ears that extend downward. The later 36-41 cast top sections have uneven input and output holes, one is higher than the other. From your photos is is hard to tell what size or the placement of the holes on the die cast top.
12-20-2021, 10:42 AM | #5 |
Re: Fuel pump ID
I agree with Terry. The one photo that we need (of the relationship of the inlet and outlet openings) isn't there.
12-20-2021, 11:11 AM | #6 |
Re: Fuel pump ID
12-20-2021, 12:39 PM | #7 | |
Re: Fuel pump ID
12-20-2021, 01:51 PM | #8 |
Re: Fuel pump ID
That it does, thank you. The pump in question is a post-'41 pump with the aligned inlet and outlet holes. The previous versions' outlet hole is noticeably below that of the inlet hole.
As Terry indicated, the stamped top cover is another telltale. It is interesting that the subject pump has the T-handled drain plug and spring. Generally speaking that was replaced with a special slotted hex head screw and fiber washer starting with the '34 version. |
12-20-2021, 03:28 PM | #9 | |
Re: Fuel pump ID
12-20-2021, 10:43 PM | #10 |
Re: Fuel pump ID
Thank you David and Pete. I have no use for it but now that we know what it is if anyone is interested I'll list it in the swap meet. I'm all about putting parts like this back in service rather than scrapping them.
Tom |
12-20-2021, 11:56 PM | #11 |
Re: Fuel pump ID
That is a 11A-9350 (1941-46) pump
12-21-2021, 05:39 PM | #12 |
Re: Fuel pump ID
I love this place. You stumble around and fine so much knowledge. I have a stash of old pumps no clue to ID. Thanks all!
12-21-2021, 08:08 PM | #13 | |
Re: Fuel pump ID
Tom |
