Old 01-23-2022, 01:48 AM   #21
Lawrie
Lawrie's Avatar
Default Re: Modifying oil pump.
You cant increase the flow of the A pump just by opening up the holes or reducing the shaft diameter.
If you could we would only need one size of pumps, but with different size holes
Lawrie
Old 01-23-2022, 09:49 AM   #22
old ugly
old ugly's Avatar
on an original engine. i am wondering why the need to modify the pump for higher flow? if the original pump with the narrower shaft is use it will fill/overfill the oil gallery which is all that is needed to oil the engine. this is why there is a oil drainback tube to take care of excess oil.
on a pressure fed engine different story.
i am wonder why the need? i see lots of discussion on oil pumps.
old ugly
my old father-in-law told me. "listen close when people tell you how to do stuff they may know something. then do it the way you want."
old ugly is offline   Reply With Quote
Old 01-23-2022, 10:39 AM   #23
daren007
Five million Model A’s left the factory without this modification.
daren007 is offline   Reply With Quote
Old 01-23-2022, 12:02 PM   #24
Bob C
But they didn't have a Burtz engine in them.
Old 01-23-2022, 12:39 PM   #25
CA Victoria
CA Victoria's Avatar
For grins and giggles I built a test fixture and tested three pump configurations. At 660 rpm i measured the time it took to pump 1 gallon of 15/30 oil at room temp; I obtained the following results:
Stock Model A Pump with 1/2” shaft - 84 seconds
Model A Pump with shaft turned to 3/8 dia - 60 seconds
59a V8 Pump modified for Model A - 38 seconds.
Albeit I’m not a NASA sanctioned test facility I resolved the debate in my mind as to the direction I was following. The pressure produced by either pump is quite worthy, the v8 pump can be easily regulated to 30 pounds. A thanks to Jim Brierley for the wealth of information in his book and taking time to answer my questions.
Tim
Downtown, Ca
CA Victoria is offline   Reply With Quote
Old 01-23-2022, 09:26 PM   #26
old ugly
old ugly's Avatar
but for a stock engine they must supply enough oil
or is there a problem?
old ugly
Old 01-23-2022, 10:01 PM   #27
Bob C
No problem for a stock Model A but this thread started as a question of
modifying a stock oil pump for use in the new Burtz engine.
Old 01-23-2022, 10:21 PM   #28
Terry Burtz, Calif
Lawrie
Stock Model A oil pumps have a small inlet window to the gears. When the intake window is enlarged to expose more gear area, the output volume increases. Larger passages have nothing to do with volume, but they will provide less friction.
old ugly
old ugly
A stock Model A engine does not need a modified oil pump.
People posting on this thread are not discussing a stock Model A engine.
Terry Burtz, Calif is offline   Reply With Quote
Old 01-23-2022, 11:04 PM   #29
RickInVA
I was taught a few things years ago I would like to throw out here and see what you think. The study of fluid flow in physics, or hydro dynamics, has some basic rules when a positive placement pump is used. The volume of the fluid flow is determined by rpm and is fixed. You can change the speed of the flow, and the fluid pressure, by the size of the openings it flows through. A small opening and the fluid flows faster to maintain the fixed volume. A wider opening will cause the fluid to flow slower. Think of a river, the volume is the river is the same even though it goes faster where the river is narrow and slower where it is wider, but the gallons per minute remains the same. The gear pump delivers a constant volume because it is a positive displacement pump and fluids are not compressable. By changing the openings in the pump you are changing the speed of flow and the pressure but not the total volume. If you want more volume you need to speed up the pump or get a pump with biggger gears. My two cents.
RickInVA is offline   Reply With Quote
Old 01-23-2022, 11:14 PM   #30
old ugly
old ugly's Avatar
Originally Posted by Chris Haynes View Post
I have read the instructions on how to increase the flow of a stock oil pump. I am limited of doing this myself because I don't have a milling machine. Is there anyone who does the work on these pumps?
i don't see a Burtz engine being mentioned here by the OP.
is he building a pressured oiling system? i guess i am not reading between the lines.
old ugly
Old 01-25-2022, 11:35 AM   #31
saxman657
Originally Posted by Russ/40 View Post
Not shure, but I suspect Chris is trying to perform the modification recommended for use in the new Burtz block for pressurizing the oil flow to all bearing surfaces, thus the desire for more flow.
I too, would like to make that modification with hand tools if someone has proved it can be safely executed
I spoke with Specialty Motor Cams this morning. There is a lighter spring that can be inserted in place of the internal "green" spring that will reduce oil pressure from a max of 50psi to approximate 8psi at idle and 18psi at 2200rpm: McMaster-Carr spring #9657K153. This is a 2" compression spring with a .313OD. Cost for a pk of 12 is $9.31. Much cheaper and easier to install than a pressure relief valve -- and for those ordering a Stipe pump for your Burtz engine, request the lighter spring for lower pressure, and this is what they will install in their oil pump.
saxman657 is offline   Reply With Quote
Old 01-25-2022, 03:40 PM   #32
Chris Haynes
Chris Haynes's Avatar
Although I didn't specify Burtz it is for one.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 01-25-2022, 04:17 PM   #33
McMimmcs
McMimmcs's Avatar
I am sure you have read post number 5 from Terry, correct?
Old 01-25-2022, 09:33 PM   #34
old ugly
old ugly's Avatar
yes but at the time i read it Terry, didn't translate to Burtz for me.
then i got thinking why does he need to modify an oil pump to that extent.
sorry
old ugly
Old 02-14-2022, 12:48 PM   #35
nkaminar
nkaminar's Avatar
If anyone is using the oil pump from Specialty Motor Cams and want to reduce the pressure by installing a lighter spring for the pressure relief valve, I have a bunch and will send you one, no charge. I bought some from McMaster Carr on advice from Stripe Machine Company. The minimum order is 12. I will use one and maybe one for a spare. The part number from McMaster Carr is 9657K153, Compression Spring 2" long by 0.313 OD. If you want one send me a PM with your mailing address.
Old 02-15-2022, 01:19 PM   #36
fr33777
I would like one. [email protected]
fr33777 is offline   Reply With Quote
