Old 11-20-2012, 11:37 AM   #1
Robert Dip
Robert Dip's Avatar
Default ’32 – 34 rear shackles not in alignment
This has been bothering me for years. The rear spring on the ’32 – ’34 is curved and the spring hangers on the rear end are fairly perpendicular to the axle housing. This causes a miss-alignment of the shackles…as if one shackle bar should be slightly longer to compensate for this. It also leads to an uneven wear distribution, which in turns causes problems in the long run.
Is this another Ford weird design like the wheels not being centred in the wheel well??
Maybe I’m missing something…any comments…..Robert
Robert Dip is offline   Reply With Quote
Old 11-20-2012, 11:58 AM   #2
Andy
Default Re: ’32 – 34 rear shackles not in alignment
You might have the wrong rear end. The 32-4 rears have the hangers angled to match the springs. You may have a 37-41 rear and that would move the rear forward.
Andy is offline   Reply With Quote
Old 11-20-2012, 12:10 PM   #3
Robert Dip
Robert Dip's Avatar
Andy, the rear ends are totally different, and '37 - '41 do not fit on '32s. I have a 'B' model '32 diff, and yes, the spring hangers are properly angled. However, I have two '34 diffs and they are straight. This is getting stranger all the time. I don't see why that is.....would be strange that somebody heated the hangers over time and made them straight. Now I'm going to have to crawl under '34's to check this out.....and who knows what has been done to these ole Fords over time. Robert
Old 11-20-2012, 12:20 PM   #4
Andy
You do have a strange one. If someone heated them and straightened them, what spring would they be using? I can only think a T or an A would fit. If the rear is a 32-34 with the radius rod mount tabs on the housings, then somone bent the hangers.
Old 11-20-2012, 12:47 PM   #5
FlatheadTed
FlatheadTed's Avatar
It is possible you have a early 32 were they angled the radius rods to match the spring ,Then later they angled the ends of the spring for a better hinging action ,at right angles to the axle
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 11-20-2012, 01:14 PM   #6
Mart
Mart's Avatar
The spring hangers are in line with the ends of the spring, in other words not at 90 degrees to the axle. If yours are straight, they must have been heated and bent.
I think Ted is referring to radius rods, which are different between 32 and 33/34, but not what the poster was asking.
Mart.
Old 11-20-2012, 02:07 PM   #7
DavidG
DavidG's Avatar
Robert,
Your spring perches on the axle housings are bent out of shape. All '32-'34 rear axle spring perches are at the same angle as the center line of the eyes of the spring, be they early or late '32s or '33s or '34s. Perhaps someone along the way used a Model A rear spring or a post-'34 rear spring and bent the axle housing spring perches to aligh with that type of straight-across rear spring (as opposed to a bent-in-the-center '32-'34 rear spring).
Old 11-20-2012, 04:24 PM   #8
Robert Dip
Robert Dip's Avatar
I now believe that my spring perches are definitely out of shape...hard to believe that they would get this way in use....the '34 rear end I have is from a pickup....must have been carrying quite a load to force then inwards....if that's the case. Yes, the 'B' diff has the bent wishbones, and the very late '32 to '34 are straight. It's the welded tab on the later models that are welded on an angle for the straight wishbone. I'll get out the torches and fix this.......I guess I am the only lucky guy to have this dilemma. Thanks guys..Robert
