09-25-2011, 07:46 PM | #1 |
•••1935-36 Ford 5w Coupe Seat: Pics and details needed!••••
I'm in a bit of a predicament while putting together my 1935 Ford 5w coupe. The car didn't come with a seat so I sought out to get one in nice condition. I found one that had been recently upholstered and bought it without thinking twice. Well it turned out to be a '37 seat I believe.
So then I have $300 in this seat and I can't turn back so I then bought a '36 base as well as the wood side panels and the "flip up" wood back frame so I can mate the two. I think mating the two isn't going to be difficult once I see how they go together. I'm concerned about that back flip up panel and how it situates itself over the trans tunnel. Just it position right over the trans tunnel and then nailed into the side panels? I'm looking for any pics (from behind, front and sides) that you guys might have. Pics of the seat assembled outside of the car is even better. I'm also looking for advice, tips and parts that I might need to complete the seat. I appreciate it in advance, JJ |
09-26-2011, 12:31 AM | #2 |
Re: •••1935-36 Ford 5w Coupe Seat: Pics and details needed!••••
The flip up panel goes on the seat back like this:
The backrest support is screwed into the plywood sides. |
09-26-2011, 09:14 AM | #3 |
Thanks Dave! I'm getting some question marks popping up where I believe that there should be images but the bottom image of the assembled frame is ver helpful.
09-26-2011, 10:08 AM | #4 |
Ok it took me a couple refreshers but I can see all the pics now.
09-26-2011, 12:10 PM | #5 |
I don't see how the trans tunnel would have anything to do with it unless you don't have the seat tracks.
Obsessed with all things 1936 Ford since birth... thanks Dad. |
09-26-2011, 01:03 PM | #6 |
09-26-2011, 01:25 PM | #7 | |
If there was any way to take a pic from behind that would be great but I know that's kinda hard. |
09-26-2011, 01:30 PM | #8 |
Pm me your phone number and I'll text you one from inside my car.
09-26-2011, 02:39 PM | #9 |
There is a piece of wood below the seat pan that goes over the tunnel.
See photo. |
09-26-2011, 02:45 PM | #10 |
So that is wood. Mine was replaced with metal...
I can take better pictures later for you if you like JJ. Last edited by Tinker; 09-26-2011 at 03:30 PM. |
09-26-2011, 02:58 PM | #11 |
You could use the metal piece, but you need to bolt in the tracks and remove the metal piece and then locate the tunnel and cut out the steel to fit. I believe this originally was there to prevent items from going from under the seat backward as well as items behind the seat from moving forward under the seat. Just a guess, it is not structural to the seat at all.
09-26-2011, 03:15 PM | #12 |
Aha!!! See that torque tube tunnel was really what I am missing. I can't imagine why it's not there or why if someone replaced it they wouldn't have needed to cut that out unless it was front whee drive now
If that's what's holding it up from aligning with the side boards I'll get the old Jig saw out tonight and cut her up! |
09-26-2011, 03:17 PM | #13 |
I should upholster the side panels before I screw that whole thing together huh?
09-26-2011, 03:29 PM | #14 | |
09-26-2011, 03:33 PM | #15 |
Hey Tinker, you see those screws that bolt your base to the side panel? Where can I get some of them? Labaron Bonney?
09-26-2011, 03:57 PM | #16 |
I'm going to guess that these came from Ace hardware.
09-26-2011, 03:58 PM | #17 |
It was already together when I removed it. I haven't started cleaning it up, yet.
I'm not building a points car so if they look decent and work well, I'll be leaving it alone. I do like to use whatever original item I can. Last edited by Tinker; 09-26-2011 at 04:10 PM. |
09-26-2011, 04:45 PM | #18 |
Hmm, my seat doesn't have that piece with the cut out. But I don't have the stock floor either.
09-26-2011, 06:02 PM | #19 |
You need to assemble the seat boards and side boards and then upholster the side panels. The inside of the side boards is where the upholtery is tacked in place.
09-26-2011, 07:07 PM | #20 | |
First picture I'm guessing is a 1930's ford factory fastener. 2nd is, I would say, a late 1990 home depot deale'o. |
