Old 10-25-2019, 08:11 PM   #1
03marauderman
Default Front Fender Brackets
What are the differences between the 28/29 & the 30/31 front fender brackets? Is the distance the same between the mounting at the frame, to the head lamp mounting?
03marauderman is offline   Reply With Quote
Old 10-26-2019, 05:06 PM   #2
Mike Peters
Mike Peters's Avatar
Default Re: Front Fender Brackets
No, the distance between the frame and headlight mounting holes is much longer on the 30-31 front fender brackets. In the first photo, the black bracket is a forged 28. The dirty grey one is an early 30 forged bracket. You can see that the headlight bar mounting is very different between the two.
The second photo is the forged 28 and forged early 30 butt to butt.
The third photo are two 30 -31 brackets, one forged, the other stamped steel. Both have identical configurations.
Mike Peters is offline   Reply With Quote
Old 10-26-2019, 07:19 PM   #3
03marauderman
OK...Excellent comparisons.....So...the headlamp mounting bar is on the 'curvature' of the bracket....for the 1930....What do you mean when you say 'early' 30? Are you referring to the 28/29 style?
Old 10-26-2019, 07:33 PM   #4
Mike Peters
03marauderman is online now Report Post
No. The early 1930 brackets were forged, like the 1928 brackets. However, they are shaped exactly the same as later 1930-31 stamped brackets. See the 3rd photo.
Old 10-26-2019, 08:55 PM   #5
03marauderman
Wow..now I see all the confusion....You really need to be an expert to decipher all the differences in years...There are some e-bay listings, as with craigslist, that are totally inaccurate, not that the sellers are trying to misrepresent, its just they are unaware of all the specifics..... I am now clear...my 30 has the forged brackets....Thank you.....Great education.......
